isgtz said:Step "5) Copy Crack file in to installation folder then run patch as administtrator" should be explained better:
5.1 Copy Crack file "amtemu.v0.9.1-painter" into installation folder (typically Windows/Programs/Adobe/Acrobat 11.0/Acrobat
5.2 Run "amtemu.v0.9.1-painter" as administtrator (a black text window will open)
5.3 Once the dialogue box opens up asking to precise the file, chose "amtlib.dll"; click open
5.4 Wait untill "WORK DONE" appears on the black window; close this window
Hopes that helps
PS. The whole set of instructions should look:
1. Stop the application if started
2. Open AcrobatPro.exe and extract it in desktop
3. In desktop go to extraxted folder then run AcroPro.msi
3.1 Select free trial when installing.
4. Click on update file AcrobatUpd11020.msp and install it
Hopes that helps
I must be dumber. I can't find it anywhere. How do I get this to register so I don't have to buy the program.Darklighter said:I am dumb....I was putting it onto my desktop, NOT in the directory I actually installed the files in...DERP - all fixed![]()
jlau21 said:When I try to run the crack file as admin, I receive this error message: "Insufficient system resources exist to complete the requested service." Any idea the work around this? Thanks!
yadsandhu said:when i start application after few minutes it gives error (A error has been detected with a required application library or file and the product cannot continue please reinstall the application) what to do /??????????????????
Hopes that helps
