Adobe Acrobat 11 Pro Activation
timw128
Adobe Acrobat XI Pro 11.0.20 FINAL
<t>Hi-<br/>
Can't seem to get Adobe Acrobat XI Pro 11.0.20 to install with 'read me' instructions...<br/>
Can anyone here please help me out?...<br/>
Thanks!</t>
micaclean
Re: Adobe Acrobat XI Pro 11.0.20 FINAL
<t>Hi, how are you, <br/>
im the same I can't seem to install Adobe Acrobat XI pro using the "read me" instructions. Can a team member please attach some screenshots from steps <br/>
<br/>
4) Install the update file 'AcrobatUpd11020.exe'<br/>
5) Copy Crack file into installation folder then run patch as administrator<br/>
DONE!<br/>
<br/>
thank you</t>
Howcho
Aug 8, 2019
6
Chrome 75.0.3770.142
I am trying to install Adobe Acrobat XI Pro 11.0.22
Although slightly different, I am having similar problems that others are experiencing.
When I run: adobe.snr.patch.v2.0-painter.exe (as administrator) I recieve the following UI.
It then states that it cannot find the file amtlib.dll and asks if I would like to search for it. I do so, click ok, and then I get the error as pictured above.
I note that there is a drop down listing many adobe products. Unfortunately Adobe XI does not appear.
Any help please?
veblen
Windows 7
Chrome 76.0.3809.137
The problem of Howcho probably was he chose to patch a 32bit application with a 64bit patch.
I used for this app:
Adobe Acrobat PRO DC 2019.010.20098 + Crack
that is not on the list of "adobe.snr.patch.v2.0-painter.exe", the last voice in the list:
"Try to patch another product with the amtlib file (32bit)" and it worked.
veblen
Windows 7
Chrome 77.0.3865.121
Unfortunately Acrobat works no more. Need other crack.
830
Chrome 77.0.3865.120
As I have mentioned before if you install any of the free Adobe products it seems they now vaccinate your system from using any cracked version of their programs or so the rumor goes. Looking at all the Adobe failures members have encountered lately I almost have to believe it's true.
TigerKing
Firefox 71.0
After installing 11.0.20 version from thumper.. I updated to latest version 11.0.23, which is running smoothly without any issue..
Thank you.
Mancunian_Nick
Windows 7
Chrome 79.0.3945.130
Figured it out, the readme is just a little off. AcrobatPro.exe is used twice instead of AcroPro.msi. And the update is .msp not .exe.
3. "In desktop go extraced folder then run AcrobatPro.exe"... should be "run AcroPro.msi".
3.5. Select free trial when installing.
4. "AcrobatUpd11020.exe" should be "AcrobatUpd11020.msp"
After that it worked like a charm. Hope that helps. Thank you Thumper!!
Thank you. Worked at last like a charm. Just need to know where to put the crack file now .. into the install directory ... where I presumably run it? Wish you'd clarified that step too but at least the acrobatupd11020 worked now. :)
Mancunian_Nick
Windows 7
Why is it so hard to get the proper instructions for this?? Where is the crack? is it the one named "amtemu.v0.9.1-painter"in the crack folder?
Yes that's right ... only file in the crack folder together with the readme.
830
Can anyone provide with a download link?
Techtools version is still floating around the torrents. Fileriver has a direct download of DC.
Honestly Adobe is dying a well deserved death. Almost all their web based stuff has been the easiest vector to inject a virus into a PC for decades now. Why Adobe never seemed to care beans for user security is unfathomable to me. If you are going to get this keep in mind it's the same old, same old protection scheme, firewall and host file blocks although even if you block it calling home some of their newer free stuff once installed seems to interfere with the crack. I wouldn't know personally. Wouldn't waste my time. If I needed to deal with PDF's there are far more secure alternatives out there.
Agba_Awo
Firefox 75.0
Please guys, I have done everything as described, I still get the 30 days trial pop up upon launching, tried uninstalling and still the same. I use window 1o.
Thanks guys
Era.khanna
OS X
Chrome 92.0.4515.107
Hey Guys I am new to this from and I am searching for Adobe for mac, can someone please guide me I will be able to get that?
830
Wrong forum. Read the forum's title. I suspect the torrent indexes might be a good place to start to look for mac stuff.
23
23
