Adobe Acrobat DC 2021.007.20099 FULL problems
Status
Not open for further replies.
ukiboy77
Hello,
I have installed DC 2021.007.20099 FULL and have been using it recently for the past 2 months without a problem. Today, I installed Adobe Photoshop CC (with a different uploader). Installation went fine and I was able to use the Photoshop. I was also then able to open some PDFs that I edited on photoshop with Acrobat. But maybe after 20 minutes, it started to have the Adobe Sign In pop up on Acrobat - which was a bummer cause it was working fine. After that, I've tried to run the patch again, restarted the computer... No luck. Still comes up. Photoshop appears to be working fine.
Any way to fix this? Uninstall this one and reinstall the new Acrobat (.20102)? Just not sure why it broke.
Any help or advice would be greatly appreciated.
Hello,
Status
