Advanced System Optimizer v3.5.1000.13742 Incl. Crack
pizzadeliver
It says "Registered Version" but it's not really registered. When you're going to use advanced functions like "Registry Optimizer" a window pops up and ask you to register your copy in order to use advanced functions.... The only thing I couldn't manage to do is "disable auto-updates"... Seems like there's no such an option (and I did the first scan with internet off, so I'm pretty sure it didn't update)
(Sry for bad english, I'm italian, and the program language is in italian too...)
PS: I put the crack file in the right place
http://Pictat.com/show.php?i=/2012/6/7/48472asp.jpg Screenshot
Well, it's working fine for me.
You install and use crack in right way and dont run any update :)
Here is screenshot:
Here is screenshot:
The registry cleaner works also for me, while some funcionts like the registry optimizer don't...
thumper said:
Yes you are right...
Seems taht Optimize is not working :$
Even the "System Protector" thing, that should remove malware, spyware and so on requires registration... Oh well switching back to Advanced System care... Thx for the help anyway
