Autodata 3.45 installation problems
siegheil
I've been trying to install Autodata, but when I get to the step to run GetUid-x64 as administrator, I just get an error message saying "Require Administrator privileges.", and I get Hardware ID 6400000000.
I am administrator, and I've tried restarting the PC and go back to step 3 which it says in the installation instructions.
Can anyone please help me?
crackwhore
Aug 24, 2017
8
I've got this to work on an old XP laptop, once it gave me an error when installing about opening a .vbs file and did not create the desktop shortcut but it still worked, second install was fine with no errors at all!! So I presume it will work in a virtual machine
da89ni
Not working under Windows 10 x64.
Followed all the steps.
Runtime error 217 at 00580D29
Any suggestions?
da89ni
Running in command prompt "regsvr32 C:\ADCDA2\ChilkatCrypt2.dll" will fix the Runtime error 217 at 00580D29
Now i have another error:
I guess the AuDaS0 driver is not started.
da89ni
I reinstalled and started manually the Dongle Emulator. Now Autodata is working.
My conclusion is that the installer is not working properly.
It's better to install all parts of the Autodata package manually: ADCDA2, RegSettings, VCRedists, SentinelDriver, Emulators, disable UAC and run all as Administrator.
Another detail that i noticed is that the Autodata package is labeled as version 3.45 but after install in the info window the version is CDA 3.44, v9.200
8,888
Thank you for your post! ;)
Ginao81
Hello.
I have done all steps according to the installation file on an XP virtual machine but it does not create the icon in the working buffer but when opening the ADCDA2 it gives the error E0209 -- SENTINEL KEY NOT FOUND
Can anyone help?
Greetings from Portugal ;) :eek:k:
8,888
siegheil said:
Run Autodata as adminsitrator (Right click > Run as administrator)
Good luck.
raunts007
I had same error (217 at 0005808D29) and and running command prompt as you said fix this error. Thanks!
mikiS
Ginao81 said:
Hello.
Can anyone help?
Same error here, except I've got it on Win 10
Thread starter Title Forum Replies Date
N Autodata 3.45 Windows 8 and 7 Help and Support 1
N Autodata 3.45 Windows 10 Help and Support 0
G autodata 3.45 test mode disable help Windows 10 Help and Support 2
A AutoData 3.45 problem error sentinel key not found. Windows 8 and 7 Help and Support 5
F AutoData data disks? Windows 8 and 7 Help and Support 0
S AutoData 3.45 keygen problem Windows 8 and 7 Help and Support 1
D autodata rruntime 217 at 00580d29 Windows 8 and 7 Software Chat and Support 5
O Cant start AutoData 3.45? Windows 8 and 7 Help and Support 1
T Autodata 3.45 Keygen problem Windows 8 and 7 Software Chat and Support 15
F autodata 3.45 missing getuid-x86.exe Windows 8 and 7 Software Chat and Support 2
T Autodata 3.45 Error Windows 8 and 7 Help and Support 0
M autodata 2.45 runtime 217 at 00580d29 Windows 8 and 7 Help and Support 4
R AutoData 3.45 Windows 10 Help and Support 45
M AutoData 3.45 Windows 8 and 7 Help and Support 10
D autodata 3.45 Windows 10 Help and Support 23
J Any Windows installation failed. Windows 8 and 7 Hardware Chat and Support 1
G Installation problem Virus, Trojan, Spyware, and Malware Removal Help 4
A Windows 10 installer has no edition selection before installation? Windows 10 Upgrade and Installation 9
A Problem in photoshop cc 2019 installation Windows 10 Software Chat and Support 1
C Installation/activation of MICROSOFT Office PRO Plus 2016 v16.0.4266.1003 RTM Windows 10 Software Chat and Support 24
DVDR_Dog Microsoft confirms installation issues in Windows 10 updates 8/19/2019 Windows 10 Upgrade and Installation 5
MikuruX Solved Nero Burning Rom Installation Issue Windows 10 Help and Support 5
J can proceed to installation for microsoft office 2016 Windows 10 Help and Support 1
G Wondershare Installation Windows 8 and 7 Help and Support 0
D AVG Internet Security Installation failure Windows 8 and 7 Help and Support 4
V Microsoft Office 2016: MISSING INSTALLATION .TXT FILE Windows 8 and 7 Help and Support 12
T Win8 Installation Error Windows 8 and 7 Help and Support 3
D How to Easily Repair Corrupted Windows 7 Installation Tutorials 1
R Problems with my brother printer after updating Windows 10 recently Windows 10 Help and Support 1
ThumperTM Search problems in Windows 10 Windows 10 Help and Support 2
O HELP windows 8.1 problems Windows 8 and 7 Help and Support 1
T adobe premiere CC 2017 problems Windows 8 and 7 Help and Support 2
C dvdfab problems? Windows 8 and 7 Help and Support 1
O problems running cs6 extended portable Windows 8 and 7 Help and Support 3
69
69
