AVS Registry Cleaner 2.2.3.236
Asmin
have down loaded AVS Registry Cleaner 2.2.3.236 (from BTjunkie) and installed same, but unable to patch. message received is "Unable to Open File". any HELP please.
Hello,
Sorry but we dont support from files which are downloaded out of ThumperDC.com.
who was uploader of this sofware? can you link me to the file where you download it?
Thanks
Hi Thumper.
hope the following helps.
Downloaded from btjunkie.
http://btjunkie.org/search?q=AVS+Registry+Cleaner
Third row down reads.
"AVS Registry Cleaner 2.2.3.236 incl Patch By ThumperTM"
Uploader:- 2011/01/03 by guest
program installed OK but patch reports "unable to read AVS Registry Cleaner.exe" file. Anti-virus switched off also Malwarebytes turned off. Still no luck.
If I have uploaded the info file twice then sorry as unsure if it uploaded 1st time, if at all.
Thanks for your help
If you download "AVS Registry Cleaner 2.2.3.236 incl Patch By ThumperTM" i can explain how to use patch...
@Asmin you either open the patch.exe and browse to C:/program files/avs registry cleaner and the patch will automatically do its thing or copy the patch to the program folder then run it from there, once patched you can delete the patch.exe (when you initially install any program always 'un-tick' run/launch now)
Let me know if you done now
Sorry Mate.
Tried everything but no luck.
The Patch takes me to the folder where the program is. I click on the program then click on OPEN then fails.
I am running Windows 7 would this make a difference?
Have uninstalled and re-installed but again no luck.
anyway thanks for your help. I will download it again from your site and try again.
Can you tell me how to change my username? as it is mis-typed
Once again thanks for your help.
Hello,
These instructions for patching it are valide for my upload no for others upload...
Change username is not allowed here but i will allow you this time... PM me what username you want
cheers
