Delete.On.Reboot 3.11
Hotrod369
May 31, 2021
213
82
Chrome 100.0.4896.162
Delete.On.Reboot is a small and effective freeware program when it comes to deleting non-erasable files, directories, subfolders in an elegant way on Windows computer restart.​
Unlike the aggressive approach of deleting locked files with ThisIsMyFile, this is the regular procedure; provided by Microsoft on all Windows OS, but here you can still also move the files to a directory for example to check the possible culprits files. easy to use!
Delete at restart key features:​
◆ Administrative Explorer
◆ Administrative Explorer with System Rights
◆ Move and Delete on Restart
◆ Remove Windows Standard Delete Jobs
Other possibilities and specifications
◆ Very small program
◆ Low CPU usage
◆ Category Automation
◆ Optional translation function
Portable
◆ Freeware
◆ Multilanguage
A very small "Reboot - Delete Tool"​
Optionally, you can add the freeware tool to the Explorer context menu via the Extras menu, all objects in the list view will be deleted from the Windows PC when restarting. If necessary, objects that should not be deleted can be removed from the list view so that they are not deleted when the Windows PC restarts. Optionally in the download area is the installable and portable version.
Created on request of the user, I worked hard and equipped it with a few extras. According to personal needs and the ideas of the users to this Windows tool it is still extending. Have fun with this nice Windows tool that will spare you some maneuvers under Windows. With under 300 KB a very small software, which is not wasting space on the hard disk, it can be deleted / removed at any time.
A simple example of using the "delete at reboot tool"​
Especially with icons cash (cache) and the thumbnails it comes to Faulty icon display or thumbnails in the Explorer window. You can google and googling or binging to get it on board. These files can now be practically wiped whit a click at Windows restart.
45
47
