Installed dvdfab, didn't restart pc
Ran the awesome crack and NOD32 got pissy with the crack throwing brd.dll in the quarantine. *-)
Disabled NOD32. Reran the patch and it worked.
If I run NOD32 while opening DVDfab it keeps throwing brd.dll into the quarantine.
If I disable NOD32 while opening dvdfad... dvdfab runs fine and shows everything unlocked. All is well.
This Normal? Does the patch remake a DVDfab.exe with the .dll embedded thus NOD getting mad?
Want to make sure I didn't get a bad patch file.
Just ran a scan and found this...
D:\Program Files (x86)\DVDFab 9\BRD.dll a variant of Win32/Packed.VMProtect.ABO trojan
Thanks again Thumper :aplause:
Update: NOD32 threw that brd.dll in quarantine after a scan. Thanks in advance
