How to share wired Internet Connection Over USB Dongle Wifi ?
linkho
Firefox 92.0
Hi all
I have a Desktop PC with Windows 10 Enterprise installed. it has Static IP with Special DNS Address for Accessing Internet through one PCI Network Card.
Now I want to use PC's Internet on my Phone and my laptop. i have one USB dongle WiFi . is it posible to share PC' internet
through this USB Dongle ? please help me....By the way, my Usb dongle is as attached picture.
Thanks in advanced.
Kind Regards.
hacxx
650
95
Windows 8.1
Chrome 91.0.4472.77
That pen drive is for pcs that doesn't have a wifi adapter. On the phone if you have Android and a router you won't need any other device to connect to the internet.
1,416
Chrome 94.0.4606.61
No not really. You could set up a LAN with the wireless but that still wouldn't give you access to the wired network, they would be two separate entities. There may be a way to get the wired network bandwidth over to the wireless LAN and make it a hotspot, but conventional Windows networking has no provision to do that. I'll have a look around if I get some free time, but I would count on it.
The fact the PC is on a hardened network just complicates things even more. I am not sure your network admin would be happy even if you figured out a way, it would be visible to them.
linkho
Firefox 92.0
Thank you very much for following my case
This video :
Youtube Link
is what i want But the presenter is using Windows 7 and i dont know how to create ad-hoc network in win 10.....Could you please see the video and help me setup ad-hoc network in win10?
Kind Regards.
hawnod
Windows 7
Chrome 94.0.4606.61
you can use an accesspoint set like tp_link to get wired internet to be a wifi internet
1- connect lan cabel to access point
2- set up awifi net work
access the wifi network using mobile or laptop
connect the pc to the access point using lan cable
linkho
Firefox 92.0
Thanks....i will check this solution
But you said "connect the pc to the access point using lan cable"......I have one Access Point that only has one Ethernet port (Attached Picture) .....I got confused ! ......May be another access point model is needed?
Anyway let me check.
Kind Regards.
1,416
Chrome 94.0.4606.61
This video :
Youtube Link
Kind Regards.
Problem here is your wired network is static. In order for this to work something has to hand out an IP for your device. Being that your wired network is not DCHP I think that may be a problem, two devices can't have the same address, that would result in collisions.
1,416
Chrome 105.0.0.0
Sorry this has turned into a bowl of spaghetti.
I am hoping what you meant is the PC was connected to the modem/router with a static IP, DNS really is another subject and really doesn't matter for this discussion. Windows can share an IP through ICS a built in module. Note that any DNS settings that the host Windows desktop is acting as a router and the DNS assigned to the desktop ethernet adaptor will be passed along to the phone/tablet/laptop, etc. The adaptor on the phone, etc. should be set to DHCP not a static IP. DCHP is normally the default setting. All settings on the wireless connected devices will be connected VIA LAN settings. The desktop WAN will only have the public facing IP and DNS settings
Enable Internet Connection Sharing (ICS) in Windows 10
27
31
