I need help with your Office 2016 + activator instructions
Status
Not open for further replies.
snazpizaz
Hi Thmper
I dont understand your instructions for this up:
It simply says:
1) Stop the application if started
2) Install application using provided installer and do not reboot
3) Run patch file
DONE!
Can you be a bit more clear about which file/s is it you want me to run when ?
1. What application is it you want me to stop if it's started exactly ?
2. Am i installing the application using the set-up exe or the autorun file ?
3. Is the patch file you then want me to run the auto run file or the KMSAuto app ?
thanks for clarification
sp :)
Niaseer
Hiya,
The KMSAuto app is the activator but make sure you run it as administrator c:
snazpizaz
hi
thanks - but is kmsauto the patch file too or is that instruction referring to the autorun file ?
What about the installing file - auto run or the exe ?
Could someone explain it clearly ?
thanks
sp
8,942
snazpizaz said:
hi
thanks
sp
First, you have to install office 2016, than make sure that office is closed then use activator file. It should do the trick.
Good luck.
snazpizaz
Hi
cool
is the auto-run file anything i should be concerned with at all or do i just leave it alone - ? ;)
acemelhaz
hi i have downloaded this but there is no activator file i have just run the application works fine am i able to use update or not ??
grwgrw
Dont see the readme file, kms app, activator.
ls Downloads/Microsoft\ Office\ for\ Mac\ 2016\ v15.13.3\ Multi\ \[TechTools.net\]/
Microsoft Office for Mac 2016 v15.13.3 Multi [TechTools.net].ISO
www.TechTools.NET - www.ThumperDC.COM.txt
$ ls /Volumes/Office\ 2016\ VL/
Microsoft_Office_2016_Volume_Installer.pkg
Where is it?
raymm
Your instructions say:
Run KMSAuto Net.exe as administrator and use the interface.
But there is no file named KMSAuto Net.exe.
There is a file named KMSAutoNet.png, but that's not an exe file, can't run that.
I've got Word 2016 installed, but under Account, it says "Activation Required". I'm understanding that if I run KMSAuto Net.exe I can active MS Office Pro Plus 2016 - is that right?
Please advise.
giladhaz
Hi I cannt instell the office 2016 on my win10. It tells me :"somthing went wrong. Sorry we ran into a problem. Error code: 30174-4 (193)
8,942
Can you please post a screenshot?
Thank you.
raymm
ThumperTM said:
Yep, run KMSAuto (make sure that your antivirus is closed)
Thanks for response, sorry for being slow, but I don't have a KMSAuto exe file.
The only exe files I have are setup.exe, setup64.exe and setup32.exe.
I ran setup32.exe. It finished, saying "Your all set! Office is installed now.".
But I open Word 2016, diologue box says "Active Office - To activate office, enter the email address that's associate diwth your Office subscription." Or "Enter a product key instead."
What should I do?
Ray
adriancorac
Dear ThmmperTM,
I read about the thread, on the activation, but currently i am using the microsoft office preview, in this case, should i just dump the icon to the trash files and install the iso package?
need your advice.
Illusion_R
raymm,
once you have downloaded the file, before you unrar it you should turn off your AV program.
I find with Norton AV it will sometimes, more often than not, removes the activator or patch before you get the chance to use it because it's seeing it as a trojan. That could be why your not finding it.
Illusion_R
Kye7
I had the same question. I just have the 2 txt files and then the .ISO. Do I just need to run the ISO file?
I don't need to register office or add an activation code?
Status
Thread starter Title Forum Replies Date
F need help picking windows 10 Windows 10 Upgrade and Installation 2
B Windows 10 Need help installing Windows 10 onto laptop running off usb drive Windows 10 Help and Support 3
C Win10 Build 19042.631 - Network error help need Windows 10 Help and Support 9
DVDR_Dog Need Help With an Odd Format Smartphones and other Devices Chat & Support 7
J I need help installing the premium version of Malwarebytes. Windows 8 and 7 Help and Support 1
B Need help installing FolderLock 7.5.2. Windows 8 and 7 Software Chat and Support 0
T Need Help for Internet Download Manager 6.28 Build 7 Portable Windows 8 and 7 Help and Support 0
B im just ignorant and need help... Windows 8 and 7 Help and Support 1
C new guy & need help Windows 8 and 7 Software Chat and Support 6
N Need help with uTorrent 3.4.2 Windows 8 and 7 Help and Support 5
J need some help my motherbroad wont boot up. Windows 8 and 7 Help and Support 4
old hippie Need help converting mkv image file to iso Windows 8 and 7 Help and Support 3
M Silly Question, but need help asap - Master Collection 5.5 Windows 8 and 7 Software Chat and Support 3
I ThumperDC I need help with your Portable Photoshop CS6 Windows 8 and 7 Help and Support 2
M Need help with driver genius 11 pro Windows 8 and 7 Software Chat and Support 13
C Need help with Auto Capture PC configuration Windows 8 and 7 Software Chat and Support 1
M Need help installing winrar Windows 8 and 7 Software Chat and Support 3
WonderWoman Need advice on doing a back up through old school methods Windows 10 Software Chat and Support 8
M Need activate my windows 10 Windows 10 Help and Support 7
I i need assistance Windows 10 Help and Support 1
DVDR_Dog Does Your Dell Need a Reload? Windows 10 Upgrade and Installation 0
DVDR_Dog Need a VPN? Hurry! General Security 11
B need activator for office 2016 pro and what pro opens an .rar Windows 8 and 7 Software Chat and Support 0
V Need special software Windows 8 and 7 Help and Support 1
M the windows 7 pack is saying i need a product key Windows 8 and 7 Software Chat and Support 8
N Need serial number for ChrisTV Online Premium Edition 6.80 ! Windows 8 and 7 Software Chat and Support 1
T NEED SOME INFORMATION Windows 8 and 7 Software Chat and Support 1
M i need Song name Windows 8 and 7 Help and Support 3
O need support for convertXtoDVD Windows 8 and 7 Help and Support 3
B help request to put a Windows 7 in FR Windows 8 and 7 Help and Support 1
C Help with activating Office 2016 Windows 10 Help and Support 2
D Help me plss to fix Windows 8 and 7 Software Chat and Support 2
DVDR_Dog Quickbooks Help! Windows 10 Software Chat and Support 4
K Hi all and mini help to acrobat pro 11 Windows 10 Software Chat and Support 2
N i got hacked, plz help Virus, Trojan, Spyware, and Malware Removal Help 8
L Help with Microsoft office 2016 Activation Windows 10 Help and Support 3
D Help! Im stuck don't know what to do anymore, 3 times BSOD makes my SSD RAW :( Windows 10 Help and Support 4
E Windows 10 Seeking Help in Free upgradation of Windows 10 Home Single Language to Professional Windows 10 Upgrade and Installation 7
W EFI partition size - please help after clean install Win 10 for Multiboot Windows 10 Upgrade and Installation 5
thief89 AnyDVD HD 8.4.4.0 HELP! Windows 8 and 7 Software Chat and Support 2
A help needed Windows 10 Help and Support 5
N Windows 10 Wondershare Filmora 8.7.4.0 help Windows 10 Help and Support 7
NickLAranda [Help] Dell Inspiron E5440 - Fan Pulsing Issues Windows 10 Hardware Chat and Support 4
O HELP windows 8.1 problems Windows 8 and 7 Help and Support 1
A Office MAC 16.19 activation [help] Windows 8 and 7 Help and Support 2
G autodata 3.45 test mode disable help Windows 10 Help and Support 2
A Adobe Acrobat XI Pro install and crack...HELP Windows 8 and 7 Software Chat and Support 0
R HELP! Network Infected Virus, Trojan, Spyware, and Malware Removal Help 5
N Help with Avast! Premier - Scans not working Windows 8 and 7 Help and Support 2
B Microsoft Windows 10 1607 Oct HELP !! Windows 8 and 7 Help and Support 0
90
91
