January 5, 2022—KB5010195 (OS Build 14393.4827) Out-of-band
Windows 10, version 1607, all editions Windows Server 2016, all editionsRelease Date:
1/5/2022
Version:
OS Build 14393.4827
11/19/20
For information about Windows update terminology, see the article about the types of Windows updates and the monthly quality update types. For an overview of Windows 10, version 1607, see its update history page.
Highlights
- Updates a known issue that might prevent you from using Remote Desktop to reach the server and also slows performance.
Improvements and fixes
This non-security update includes quality improvements. Key changes include:- Addresses a known issue that might prevent you from using Remote Desktop to reach the server. In some circumstances, the server might stop responding. The screen might also appear black, and general performance and signing in might be slow.
Known issues in this update
Symptom | Workaround |
After installing updates released April 22, 2021 or later, an issue occurs that affects versions of Windows Server that are in use as a Key Management Services (KMS) host. Client devices running Windows 10 Enterprise LTSC 2019 and Windows 10 Enterprise LTSC 2016 might fail to activate. This issue only occurs when using a new Customer Support Volume License Key (CSVLK). Note This does not affect activation of any other version or edition of Windows. Client devices that are attempting to activate and are affected by this issue might receive the error, "Error: 0xC004F074. The Software Licensing Service reported that the computer could not be activated. No Key Management Service (KMS) could be contacted. Please see the Application Event Log for additional information." Event Log entries related to activation are another way to tell that you might be affected by this issue. Open Event Viewer on the client device that failed activation and go to Windows Logs > Application. If you see only event ID 12288 without a corresponding event ID 12289, this means one of the following:
| We are working on a resolution and will provide an update in an upcoming release. |
How to get this update
Before installing this updateMicrosoft strongly recommends you install the latest servicing stack update (SSU) for your operating system before installing the latest cumulative update (LCU). SSUs improve the reliability of the update process to mitigate potential issues while installing the LCU and applying Microsoft security fixes. For general information about SSUs, see Servicing stack updates and Servicing Stack Updates (SSU): Frequently Asked Questions.
If you are using Windows Update, the latest SSU (KB5005698) will be offered to you automatically. To get the standalone package for the latest SSU, search for it in the Microsoft Update Catalog.
Install this update
Release Channel | Available | Next Step |
Windows Update and Microsoft Update | No | See the other options below. |
Windows Update for Business | No | See the other options below. |
Microsoft Update Catalog | Yes | To get the standalone package for this update, go to the Microsoft Update Catalog website. |
Windows Server Update Services (WSUS) | No | See the other options above. |
