I have a micro SD card which suddenly says it is write-protected. I made sure the small tab on the side was in the proper position. I also tried the disk part method but it had no effect on the read only status. Sonneriesgratuite.com
I see there's another possible solution by editing the registry, but I'm worried that that would apply to all drives. Any suggestions? I don't want to erase all the files on the drive.
And I tried 2 different adapters, which work on another SD card.
nokia ringtone: https://sonneriesgratuite.com/nokia/
Thanks.
Thanks.
