- Nov 5, 2018
This is kind of a stupid question and there should be a simple answer, however I can't find it.
Here goes:
I have a few Victsing model PC 134B Vertical Optical Mice.
These are great for a guy with big hands like me.
Now the problem is the center wheel on the mouse has a switch connected that is actuated by pressing down on the mouse.
This switch changes the mouse to scroll by moving the mouse and the scroll wheel is disabled until you press the wheel again.
Unfortunately that the internal switch is sensitive and is actuated while trying to scroll up with the wheel.
I have scoured the Internet for a solution. Some mice have software that will disable that feature, Victsing does not and the software is brand specific.
There has to be a setting somewhere or a registry entry that can disable that switch. Disassembling the mouse is very difficult so I guess I could take it all the way apart. The problem is the glide pads all need to be removed and they never are as good after cleaning and reapplication of 3M heavy duty double stick tape.
Who here knows more than I do and can help me out of this predicament? Thanks
Here goes:
