PotPlayer: alternative for VLC
imo
VIP Donator
39
Powerful media player with support for lots of formats
There are a lot of free third-party media players and PotPlayer is another great option for both video and music playback.
While most people listen to streaming music or video now, there are occasions when you do not have a data connection and locally stored files are your only option. PotPlayer is an excellent media player that can handle a large variety of media file types.
Playback quality will depend on the hardware the program is installed on, but in tests, PotPlayer had no problem playing a 1.6 GB MOV file, 865 MB MKV, or a 1.4 GB AVI. Smaller files should play back without any issues as well. You can toggle file information and see an in-depth breakdown of file information including CPU usage.
[imgth]http://1.bp.blogspot.com/-T0RGIDZ_RUs/UPGEd2as-MI/AAAAAAAAQAc/a9wcsW1A7kg/s1600/PotPlayer+1.5.35188+Stable+x86x64.jpg[/imgth]
You Can Download It Here
http://potplayer.en.softonic.com/download
Recent changes
Added equal condition to auto selection criteria of configuration management
Added support for madVR's pixel shader feature
Added support for SUP (Blu-ray) subtitles
Added the ability to play MP3 files with lyrics subtitles
Added support for DIVX (XSUB) subtitles
Added the ability to swap stereo channels
Added the ability to set capture folders in one place (F5 > Capture Folder)
Fixed a problem while reflecting subtitle sync
Fixed abnormal operation when playing certain BIK files
Some fixes for DVD subtitles and DVD menu with using DXVA2
Improved Pixel shader handling
Improved logo handling
Added support for Daum Cloud https
Bookmarks is now limited up to 2000
Improved automatic selection conditions of configuration management
Enjoy :D
Alot more to come ;)
