Ok as we all know the torrenting scene changes every day with new protocols one needs a fast and mean setup.
1 ) Lets start by opening Qbittorrent and under TABS select Options as shown in the image Below
2 ) NOW SELECT THE Connection Tab and set the settings as shown in the image below
3 ) Select the Speed Tab and set the settings as shown in this image below.
Note the Global Rate Limit DOWNLOADS is set to 15mb or 15360KB/s this is
where we control the download speed we want to achieve.
(EXAMPLE) I have a 947MB upload and a 947MB Download I set the download
speed in my case to minimize the impact on my connection when I am Downloading
I chose 15MB works fine for me in many cases with just 1 seeder I get 15MB.
I have seen tutorials suggesting we set the global rate limit to 80% of your connection
speed we suggest 2% to 10% otherwise others on the same connection will be slow and choppy at 80%
4 ) In the BitTorrent Tab set the settings as shown in the image below.
5 ) The trackers list below contains the best trackers both regular and VPN
Note in some cases you may need to use port forwarding on the router for the port used for incoming connections
we used in option 2 ) of this tutorial
If you give this a try PLEASE post your findings and tell us what you think.
Kudos From AFFA Social https://www.affasocial.com
Always remember torrent responsibly and safe and
ALWAYS USE A VPN
udp://tracker.uw0.xyz:6969/announce
udp://tracker.kamigami.org:2710/announce
http://tracker.files.fm:6969/announce
https://tracker.cyber-hub.net/announce
udp://opentracker.i2p.rocks:6969/announce
udp://tracker.zerobytes.xyz:1337/announce
https://tracker.nitrix.me:443/announce
http://novaopcj.icu:10325/announce
udp://aaa.army:8866/announce
https://tracker.imgoingto.icu:443/announce
udp://tracker.shkinev.me:6969/announce
udp://blokas.io:6969/announce
udp://api.bitumconference.ru:6969/announce
udp://cutiegirl.ru:6969/announce
udp://ln.mtahost.co:6969/announce
udp://vibe.community:6969/announce
udp://tracker.vulnix.sh:6969/announce
udp://wassermann.online:6969/announce
udp://kanal-4.de:6969/announce
udp://mts.tvbit.co:6969/announce
udp://adminion.n-blade.ru:6969/announce
udp://benouworldtrip.fr:6969/announce
udp://sd-161673.dedibox.fr:6969/announce
udp://47.ip-51-68-199.eu:6969/announce
udp://cdn-1.gamecoast.org:6969/announce
udp://daveking.com:6969/announce
http://rt.tace.ru:80/announce
udp://forever-tracker.zooki.xyz:6969/announce
udp://free-tracker.zooki.xyz:6969/announce
udp://tracker.publictracker.xyz:6969/announce
udp://tracker.skynetcloud.site:6969/announce
udp://tracker.altrosky.nl:6969/announce
http://5rt.tace.ru:60889/announce
https://tracker.lilithraws.cf:443/announce
http://tracker.sakurato.xyz:23333/announce
http://tracker3.itzmx.com:6961/announce
http://h4.trakx.nibba.trade:80/announce
udp://line-net.ru:6969/announce
udp://tracker.dyne.org:6969/announce
udp://mail.realliferpg.de:6969/announce
udp://storage.groupees.com:6969/announce
udp://torrent.tdjs.tech:6969/announce
udp://tracker.v6speed.org:6969/announce
udp://cdn-2.gamecoast.org:6969/announce
udp://bms-hosxp.com:6969/announce
udp://teamspeak.value-wolf.org:6969/announce
udp://koli.services:6969/announce
udp://inferno.demonoid.is:3391/announce
udp://ipv4.tracker.harry.lu:80/announce
udp://tracker.ds.is:6969/announce
udp://retracker.akado-ural.ru:80/announce
udp://discord.heihachi.pw:6969/announce
udp://chanchan.uchuu.co.uk:6969/announce
udp://aruacfilmes.com.br:6969/announce
udp://edu.uifr.ru:6969/announce
udp://publictracker.xyz:6969/announce
udp://www.torrent.eu.org:451/announce
http://vps02.net.orel.ru:80/announce
udp://bt2.archive.org:6969/announce
http://tracker.noobsubs.net:80/announce
udp://tracker.zum.bi:6969/announce
udp://dpiui.reedlan.com:6969/announce
udp://engplus.ru:6969/announce
udp://ultra.zt.ua:6969/announce
udp://nagios.tks.sumy.ua:80/announce
udp://61626c.net:6969/announce
udp://t2.leech.ie:1337/announce
https://trakx.herokuapp.com:443/announce
udp://bt1.archive.org:6969/announce
https://tracker.tamersunion.org:443/announce
udp://t1.leech.ie:1337/announce
udp://us-tracker.publictracker.xyz:6969/announce
udp://tracker.dler.org:6969/announce
udp://t3.leech.ie:1337/announce
udp://3rt.tace.ru:60889/announce
udp://valakas.rollo.dnsabr.com:2710/announce
udp://rutorrent.frontline-mod.com:6969/announce
udp://opentor.org:2710/announce
udp://adm.category5.tv:6969/announce
udp://tracker.army:6969/announce
udp://tracker2.dler.org:80/announce
udp://tracker.fortu.io:6969/announce
http://bt.3kb.xyz:80/announce
https://1337.abcvg.info:443/announce
udp://tracker0.ufibox.com:6969/announce
udp://movies.zsw.ca:6969/announce
udp://code2chicken.nl:6969/announce
udp://u.wwwww.wtf:1/announce
udp://tracker.0x.tf:6969/announce
http://publictracker.ch:6969/announce
udp://bioquantum.co.za:6969/announce
udp://www.midea123.z-media.com.cn:6969/announce
http://retracker.sevstar.net:2710/announce
udp://tracker.blacksparrowmedia.net:6969/announce
udp://git.vulnix.sh:6969/announce
udp://admin.videoenpoche.info:6969/announce
udp://tracker.torrent.eu.org:451/announce
http://t.nyaatracker.com:80/announce
udp://tracker.doko.moe:6969/announce
http://asnet.pw:2710/announce
udp://thetracker.org:80/announce
http://tracker.tfile.co:80/announce
http://pt.lax.mx:80/announce
udp://santost12.xyz:6969/announce
udp://bt.xxx-tracker.com:2710/announce
udp://tracker.vanitycore.co:6969/announce
udp://zephir.monocul.us:6969/announce
http://tr.kxmp.cf:80/announce
udp://bt.aoeex.com:8000/announce
udp://tracker.tiny-vps.com:6969/announce
udp://tracker.tvunderground.org.ru:3218/announce
udp://tracker.halfchub.club:6969/announce
udp://retracker.nts.su:2710/announce
udp://wambo.club:1337/announce
udp://tracker.dutchtracking.com:6969/announce
udp://tc.animereactor.ru:8082/announce
udp://tracker.justseed.it:1337/announce
udp://tracker.leechers-paradise.org:6969/announce
udp://tracker.opentrackr.org:1337/announce
udp://tracker.coppersurfer.tk:6969/announce
udp://open.stealth.si:80/announce
udp://inferno.demonoid.pw:3418/announce
udp://tracker.cypherpunks.ru:6969/announce
udp://tracker.cyberia.is:6969/announce
udp://tracker2.christianbro.pw:6969/announce
udp://retracker.lanta-net.ru:2710/announce
udp://tracker.internetwarriors.net:1337/announce
udp://ulfbrueggemann.no-ip.org:6969/announce
udp://peerfect.org:6969/announce
udp://tracker.swateam.org.uk:2710/announce
http://ns349743.ip-91-121-106.eu:80/announce
http://agusiq-torrents.pl:6969/announce
udp://explodie.org:6969
udp://public.popcorn-tracker.org:6969/announce
udp://tracker.ilibr.org:80/announce
http://atrack.pow7.com/announce
http://secure.pow7.com/announce
http://t1.pow7.com/announce
http://t2.pow7.com/announce
http://thetracker.org:80/announce
http://torrentsmd.com:8080/announce
http://tracker.bittor.pw:1337/announce
http://tracker.dutchtracking.com:80/announce
http://tracker.dutchtracking.nl:80/announce
http://tracker.edoardocolombo.eu:6969/announce
http://tracker.ex.ua:80/announce
http://tracker.kicks-ass.net:80/announce
http://tracker1.wasabii.com.tw:6969/announce
http://tracker2.itzmx.com:6961/announce
http://www.wareztorrent.com:80/announce
udp://62.138.0.158:6969/announce
udp://eddie4.nl:6969/announce
udp://explodie.org:6969/announce
udp://shadowshq.eddie4.nl:6969/announce
udp://shadowshq.yi.org:6969/announce
udp://tracker.eddie4.nl:6969/announce
udp://tracker.mg64.net:2710/announce
udp://tracker.sktorrent.net:6969
udp://tracker2.indowebster.com:6969/announce
udp://tracker4.piratux.com:6969/announce
http://tracker.dutchtracking.com/announce
http://tracker.mg64.net:6881/announce
http://tracker.tfile.me/announce
http://tracker2.wasabii.com.tw:6969/announce
udp://tracker.mg64.net:6969/announce
http://tracker.opentrackr.org:1337/announce
udp://zer0day.ch:1337/announce
udp://zer0day.to:1337/announce
http://explodie.org:6969/announce
udp://9.rarbg.com:2710/announce
udp://9.rarbg.me:2780/announce
udp://9.rarbg.to:2730/announce
udp://p4p.arenabg.com:1337/announce
udp://tracker.sktorrent.net:6969/announce
http://p4p.arenabg.com:1337/announce
udp://tracker.aletorrenty.pl:2710/announce
http://tracker.aletorrenty.pl:2710/announce
http://tracker.bittorrent.am/announce
udp://tracker.kicks-ass.net:80/announce
http://tracker.kicks-ass.net/announce
http://tracker.baravik.org:6970/announce
udp://torrent.gresille.org:80/announce
http://torrent.gresille.org/announce
http://tracker.skyts.net:6969/announce
http://tracker.internetwarriors.net:1337/announce
udp://tracker.skyts.net:6969/announce
http://tracker.dutchtracking.nl/announce
udp://tracker.yoshi210.com:6969/announce
udp://mgtracker.org:2710/announce
http://tracker.yoshi210.com:6969/announce
http://tracker.tiny-vps.com:6969/announce
udp://tracker.filetracker.pl:8089/announce
udp://tracker.ex.ua:80/announce
udp://91.218.230.81:6969/announce
https://www.wareztorrent.com/announce
http://www.wareztorrent.com/announce
http://tracker.filetracker.pl:8089/announce
http://tracker.ex.ua/announce
http://tracker.calculate.ru:6969/announce
udp://tracker.grepler.com:6969/announce
udp://tracker.flashtorrents.org:6969/announce
udp://tracker.bittor.pw:1337/announce
http://tracker.tvunderground.org.ru:3218/announce
http://tracker.grepler.com:6969/announce
http://tracker.flashtorrents.org:6969/announce
http://retracker.gorcomnet.ru/announce
http://bt.pusacg.org:8080/announce
http://87.248.186.252:8080/announce
udp://tracker.kuroy.me:5944/announce
udp://182.176.139.129:6969/announce
http://tracker.kuroy.me:5944/announce
http://retracker.krs-ix.ru/announce
http://open.acgtracker.com:1096/announce
udp://208.67.16.113:8000/announce
http://tracker.dler.org:6969/announce
http://bt2.careland.com.cn:6969/announce
http://open.lolicon.eu:7777/announce
udp://213.163.67.56:1337/announce
http://213.163.67.56:1337/announce
udp://185.86.149.205:1337/announce
http://74.82.52.209:6969/announce
udp://94.23.183.33:6969/announce
udp://74.82.52.209:6969/announce
udp://151.80.120.114:2710/announce
udp://109.121.134.121:1337/announce
udp://168.235.67.63:6969/announce
http://109.121.134.121:1337/announce
udp://178.33.73.26:2710/announce
http://178.33.73.26:2710/announce
http://85.17.19.180/announce
udp://85.17.19.180:80/announce
http://210.244.71.25:6969/announce
http://213.159.215.198:6970/announce
udp://191.101.229.236:1337/announce
http://178.175.143.27/announce
udp://89.234.156.205:80/announce
http://91.216.110.47/announce
http://114.55.113.60:6969/announce
http://195.123.209.37:1337/announce
udp://114.55.113.60:6969/announce
http://210.244.71.26:6969/announce
udp://107.150.14.110:6969/announce
udp://5.79.249.77:6969/announce
udp://195.123.209.37:1337/announce
udp://37.19.5.155:2710/announce
http://107.150.14.110:6969/announce
http://5.79.249.77:6969/announce
udp://185.5.97.139:8089/announce
udp://194.106.216.222:80/announce
https://104.28.17.69/announce
http://104.28.16.69/announce
http://185.5.97.139:8089/announce
http://194.106.216.222/announce
http://80.246.243.18:6969/announce
http://37.19.5.139:6969/announce
udp://5.79.83.193:6969/announce
udp://46.4.109.148:6969/announce
udp://51.254.244.161:6969/announce
udp://188.165.253.109:1337/announce
http://91.217.91.21:3218/announce
http://37.19.5.155:6881/announce
http://46.4.109.148:6969/announce
http://51.254.244.161:6969/announce
http://104.28.1.30:8080/announce
http://81.200.2.231/announce
http://157.7.202.64:8080/announce
udp://128.199.70.66:5944/announce
http://128.199.70.66:5944/announce
http://188.165.253.109:1337/announce
http://93.92.64.5/announce
http://173.254.204.71:1096/announce
udp://195.123.209.40:80/announce
udp://62.212.85.66:2710/announce
http://125.227.35.196:6969/announce
http://59.36.96.77:6969/announce
http://87.253.152.137/announce
http://158.69.146.212:7777/announce
udp://tracker.piratepublic.com:1337/announce
ALWAYS USE A VPN
