Question regarding "MICROSOFT Office PRO Plus 2024 v16.0.17928.20148 "
gri
Location
Penistown
"KMS_VL_ALL_AIO_v53.cmd" from that torrent is recognized as a Trojan by 12 different scanners on Virustotal. I would assume this is normal for a KMS.cmd activator but i am not sure so I wanted to ask here just to be sure before running it. Has been a while since i last torrented something.
You betcha. All KMS programs are on the Microsoft hit list. They are harmless to Windows, Make sure you disable or exit any a/v you have. IMPORTANT Even though you have disabled your A/V or Windows Defender (Security) you need you rt click on the defender icon in the taskbar. Open security dashboard then virus and threat protection. Then virus and threat protection and disable real-time protection. Always do this step, otherwise KMS is going to be instantly removed from you downloads or when you unzip it, every time.
Interesting. My windows defender did instantly put it in quarantine after download but I was able to just restore it from quarantine and now defender automatically ignores that item. Will probably still have to disable it for the actual install I wager.
I've just installed this version of Office Pro Plus 2024. I followed the instructions carefully, including running the activator as administrator, but it's still asking me for a product key, and won't work without one.
Any advice?
Thanks
I gave up on KMS and stick to MAS activation. Haven't tried it on the 2024 edition, it should work just fine.
