Stormforce
- Oct 6, 2021
- 11
- 1
When i click on a folder it takes 5 seconds to open. When i click on a 32Gb Movie it takes 5 minutes to open can anyone help
Ryzen 7 5800
RTX3060
16Gb Ram
Ryzen 7 5800
RTX3060
16Gb Ram
Note: this_feature_currently_requires_accessing_site_using_safari
That's a good question I can't answer. If you look at my previous posts I have had problems with VLC too. I installed HEVC codec and PowerDVD and I have all but abandoned VLC for the present.Here is some info i collected Using VLC (the supposed best media player)
results from Task Manager
CPU : 2%
MEM : 3.7 %
Disk 1 : 97% ( where the video is installed )
time to start watching 10 min 50 sec
I installed Video Inspector and when i ran the same video it took the hughmongus time of 4 Sec to watch
what is wrong with VLC
Ryzen 7 5800
RTX3060
16Gb Ram
If your 2Tb HDD is full you're probably having swap problems. Remember your 32Gb move is stored all over that 2Tb. So, it is having to search the entire 2Tb to retrieve the movieThankyou for your answers
1 I don't use anti virus other than Defender
2. sfc /scannow has no integrity violations
3. DISM shows no problems
4. All the movies are on a 2TB spinner along with nothing else
