WinBin2Iso 1.69
Update on: July 1th 2012
This small program converts BIN CD images to ISO images. Files over 2GB are also no problem. When it comes to a quick convert, is exactly the WinBin2Iso conversion tool that you need.
Operating systems: Windows 7, Windows Server 2008, Windows Vista, Windows 2003, Windows XP, Windows 2000, Windows Me, Windows NT, Windows 98
Start the program. The first time that you use it the program it will present you with a license screen. The program is free and the license info is only displayed the first time (per PC).
WinBinToIso does not have to be installed and can be executed easily from the desktop, and can be carried on a small usb-stick or other memory device.
# Features
- Very small program
- Low CPU usage
- Convert BIN CD and DVD images to ISO images
- support BIN and ISO files over 2GB
- Portable
- Multilingual
# Versions History
New in version 1.69 // July 1th 2012
Some improvements for x64 operating systems and language files update.
Requirements:
Microsoft Windows : Servers 2000/2003/2005 Win 98/XP/Vista and Windows-7 x64/x86
Version History and change log
Download link:
# Features
- Low CPU usage
- Portable
- Multilingual
# Versions History
Requirements:
New in version 1.67 // May 20th 2012
1. New language in Win-Bin-2-Iso: Greek, Swedish
2. General optimization in WinBin2Iso
Thanks to geogeo.gr for the Greek language
Thanks to Åke Engelbrektson for the Swedish language
New in version 1.66 // April 11th 2012
1. New language in "Win Bin 2 Iso": Italian
Thanks to delisa1996 and vito di lascio for the Italian language.
New in version 1.64.92 // March 13th 2012
1. New language in "Win Bin 2 Iso": French
http://www.softwareok.com/?Download=WinBin2Iso
