Wireshark- 1.8.0
Wireshark.org - (Open Source)
Description
Wireshark is the world's foremost network protocol analyzer, and is the de
facto standard across many industries and educational institutions.
Deep inspection of hundreds of protocols, with more being added all the
time
Live capture and offline analysis
Standard three-pane packet browser
Multi-platform: Runs on Windows, Linux, OS X, Solaris, FreeBSD, NetBSD,
and many others
Captured network data can be browsed via a GUI, or via the TTY-mode
TShark utility
The most powerful display filters in the industry
Rich VoIP analysis
Read/write many different capture file formats
Capture files compressed with gzip can be decompressed on the fly
Live data can be read from Ethernet, IEEE 802.11, PPP/HDLC, ATM,
Bluetooth, USB, Token Ring, Frame Relay, FDDI, and others (depending on your
platfrom)
Decryption support for many protocols, including IPsec, ISAKMP, Kerberos,
SNMPv3, SSL/TLS, WEP, and WPA/WPA2
Coloring rules can be applied to the packet list for quick, intuitive
analysis
Output can be exported to XML, PostScript®, CSV, or plain text
OS Requirements
Windows 32-64 / MAC OS X 10.5 and later Intel 32-64
Size
Download
Description
time
and many others
TShark utility
Rich VoIP analysis
platfrom)
analysis
OS Requirements
Size
19.94MB
http://www.wireshark.org/
