April 21, 2022—KB5012636 (OS Build 17763.2867) Preview
Windows 10 Enterprise 2019 LTSC Windows 10 IoT Enterprise 2019 LTSC More...Release Date:
4/21/2022
Version:
OS Build 17763.2867
11/17/20
For information about Windows update terminology, see the article about the types of Windows updates and the monthly quality update types. For an overview of Windows 10, version 1809, see its update history page.
Highlights
- Updates non-security issues for your Windows operating system.
Improvements
This non-security update includes quality improvements. Key changes include:- New! Adds improvements for servicing the Secure Boot component of Windows.
- Addresses an issue in which certain Point of Sale terminals experience occasional OS startup delays during restart of up to 40 minutes.
- Addresses an issue that causes a remote desktop session to close or a reconnection to stop responding while waiting on the accessibility shortcut handler (sethc.exe).
- Addresses an issue that incorrectly returns Execution Policy settings from the registry.
- Addresses an issue that causes the Key Distribution Center (KDC) code to incorrectly return the error message “KDC_ERR_TGT_REVOKED” during domain controller shutdown.
- Addresses an issue that might cause Windows to stop working when you apply a Windows Defender Application Control (WDAC) policy that doesn’t require a restart.
- Addresses an issue that might fail to copy the security portion of a Group Policy to a machine.
- Addresses an issue that causes the primary domain controller (PDC) of the root domain to generate warning and error events in the System log. This issue occurs when the PDC incorrectly tries to scan outgoing-only trusts.
- Addresses an issue that might prevent graphics processing unit (GPU) load balancing over Remote Desktop from working as intended.
- Addresses an issue that might occur when you use Netdom.exe or the Active Directory Domains and Trusts snap-in to list or modify name suffixes routing. These procedures might fail. The error message is, "Insufficient system resources exist to complete the requested service." This issue occurs after installing the January 2022 security update on the primary domain controller emulator (PDCe).
- Addresses an issue that affects a Server Message Block (SMB) multichannel connection and might generate a 13A or C2 error.
- Addresses an issue that causes a deadlock in the WebDav redirector. This issue occurs when you attempt to read a file from the local TfsStore, which causes the system to stop responding.
- Addresses an issue that causes virtual computer object (VCO) password settings failure on a distributed network name resource.
- Addresses an issue that might cause the server to lock up because the nonpaged pool grows and uses up all memory. After a restart, the same issue occurs again when you try to repair the damage.
Windows 10 servicing stack update - 17763.2865
This update makes quality improvements to the servicing stack, which is the component that installs Windows updates. Servicing stack updates (SSU) ensure that you have a robust and reliable servicing stack so that your devices can receive and install Microsoft updates.Known issues in this update
Click or tap to view the known issues
How to get this update
Before installing this updateMicrosoft now combines the latest servicing stack update (SSU) for your operating system with the latest cumulative update (LCU). SSUs improve the reliability of the update process to mitigate potential issues while installing the LCU. For general information about SSUs, see Servicing stack updates and Servicing Stack Updates (SSU): Frequently Asked Questions.
Prerequisite:
You must install the August 10, 2021 SSU (KB5005112) before installing the LCU.
Install this update
Release Channel | Available | Next Step |
Windows Update or Microsoft Update | Yes | Go to Settings > Update & Security > Windows Update. In the Optional updates available area, you’ll find the link to download and install the update. |
Windows Update for Business | No | None. These changes will be included in the next security update to this channel. |
Microsoft Update Catalog | Yes | To get the standalone package for this update, go to the Microsoft Update Catalog website. |
Windows Server Update Services (WSUS) | No | You can import this update into WSUS manually. See the Microsoft Update Catalog for instructions. |
To remove the LCU after installing the combined SSU and LCU package, use the DISM/Remove-Package command line option with the LCU package name as the argument. You can find the package name by using this command: DISM /online /get-packages.
Running Windows Update Standalone Installer (wusa.exe) with the /uninstall switch on the combined package will not work because the combined package contains the SSU. You cannot remove the SSU from the system after installation.
File information
For a list of the files that are provided in this update, download the file information for cumulative update 5012636.
For a list of the files that are provided in the servicing stack update, download the file information for the SSU - version 17763.2865.
