Autodata 3.45 Keygen problem
tumble220
Hello to everyone, this is my first post. Im trying to load Autodata 3.45, i think i have loaded it right but when i click on the desktop icon, it come up with the message "E0209 - Sentinal key not found". The Keygen code keeps coming up as 6400000000, but the instructions say (in case your UID is 6400000000 you must restart/reboot your PC and go back to step 3 because that UID is NOT proper and valid). Does anyone know if im doing it wrong or is there another way of getting a different code. Any help or advice would be very much appreciated. Thanks in advance, Gary.
Hi Alex. Thanks for reply. I would be very grateful if you would upload it. What do you need me to do?. Regards, Gary.
Here u go https://mega.nz/#!2xV2VZIL!1qDiJKddUI6HLAq-jBixQtQVuiKH_uNAkQK4WyubjPw
Thanks. Im just waiting for it to download via BitTorrent. Does this work with any windows and 32bit / 64bit?
Thanks for your advice and help. I will try it when its downloaded and let you know if its worked for me. Should this one give me a different keygen to the 6400000000 i had?
Hi. Only me again. Im not very technical minded but know a little bit. Ive downloaded the thing you sent me and when i open it, it comes up with copy this image to DVD. Is this correct?
I have the same problem, it says "require administrator privileges (even though I run as administrator).
Can anyone help me?
Tried with w10 and w7
Hi guys did you you ever get this working? Ive tried installing it but i get sentinel error message. Im using W10 pro, couple other post say it doesnt work on w10..?
