[Encryption] - TrueCrypt
alpha1911
Active Member
Oct 4, 2012
33
TrueCrypt
TrueCrypt is an excellent open source disk encryption system for Windows, Mac, and Linux systems. Users can encrypt entire filesystems, which are then on-the-fly encrypted/decrypted as needed without user intervention beyond initially entering their passphrase. A clever hidden volume feature allows you to hide a second layer of particularly sensitive content with plausible deniability about whether it even exists. Then if you are forced to give up your passphrase, you give them the first-level secret. That only allows them access to the innocuous material you have there, without proving that a second level key even exists.
http://www.truecrypt.org/
Obit11
77
Re: Freeware Encryption - TrueCrypt
<r>Thanks for share <E>;)</E></r>
