I need some help please
Usually the downloaded Windows builds are only for fresh installs not for upgrades. I suggest you download an un-touched versions to do a upgrade otherwise they wont work. then when done us KMS to activate it when finished. You can also use KMS to activate the windows 7 then use a un-touched version to do the UPGRADE.
Windows 10 won’t upgrade from Windows 7 Ultimate if it’s not activated. You’ll need to activate Windows 7 first or do a clean install of Windows 10. If you choose a clean install, make sure to back up your data and have a valid Windows 10 product key ready.
