website stat Java 7 0Day vulnerability. Important info regarding | The Windows Forum
fattiechef
The cat is out of the bag. There is a 0-day out there currently being used in targeted attacks. The number of these attacks has been relatively low, but it is likely to increase due to the fact that this is a fast and reliable exploit that can be used in drive-by attacks and all kinds of links in emails. Interestingly
READ MORE
http://www.deependresearch.org/2012/08/java-7-0-day-vulnerability-information.html
Guys i would take this serious, just like any security issues , when it comes to your privacy and such a vulnerability like this ;to take note and read more, don't forget to read about the payload part of the exploit.DISABLE JAVA.
http://blog.fireeye.com/research/2012/08/zero-day-season-is-not-over-yet.html
Basically
A new browser-based exploit for a Java vulnerability that allows attackers to execute arbitrary code on client systems has been spotted in the wild – and because of Oracle's Java patch schedule, it may be some time before a fix becomes widely available.
The vulnerability is present in the Java Runtime Environment (JRE) version 1.7 or later, Atif Mushtaq of security firm FireEye reported on Sunday, while PCs with Java versions 1.6 or earlier installed are not at risk.
The vulnerability allows attackers to use a custom web page to force systems to download and run an arbitrary payload – for example, a keylogger or some other type of malware. The payload does not need to be a Java app itself.
In the form in which it was discovered, the exploit only works on Windows machines, because the payload that it downloads is a Windows executable. But the hackers behind the Metasploit penetration testing software say they have studied the exploit and found that it could just as easily be used to attack machines running Linux or Mac OS X, given the appropriate payload
