website stat Move Window & Resize Window, by any place, Move Window with Tabs, Drag Window by clicking anywhere | The Windows Forum
Tvlao
If someone is interested in ready-made scripts, and not writing everything themselves, and saving a lot of time, then here is a large collection of all kinds of scripts that do everything that may usually be required.
All these scripts are compiled into one program - QuickHotkeys.
There is a playlist on [Youtube](https://www.youtube.com/playlist?list=PLVkS_eTsfH-sEFw55o5UkRK7uMNIyICXb) about this.
And here you can [download](https://sourceforge.net/projects/quickhotkeys/).
This makes many things convenient and fast.
Here are almost all the things that have already been discussed many times on the forum, with a reliable implementation. Everything works without bugs.
( Note: to make this work without any bugs, run the program as Administrator. I always do this. I always have this program on, it always works, I never turn it off).
It has everything to make your work easier, faster, more convenient, automate common tasks, everything to work easily and quickly. These are all sorts of advanced productivity features.
Every Windows user should have this tool.
It is difficult to do without it for those who have already used it.
You don't need to configure anything, everything is already configured. You can start working right away. First, watch the video on [Youtube](https://www.youtube.com/playlist?list=PLVkS_eTsfH-sEFw55o5UkRK7uMNIyICXb).
And in the Settings menu (in the tray), there is a detailed description of everything.
Here are some things it can do:
✅ Move windows with two mouse buttons.
✅ Move windows only in a straight line.
✅ Move windows with keyboard buttons.
✅ Resize windows.
✅ Resize windows from both sides at once.
✅ Snap a window to the edges of the screen, to other windows, and to the middle of the screen.
✅ Center a window in the middle of the screen.
✅ Maximize a window to the full height of the screen.
✅ Maximize a window to the full width of the screen.
✅ Minimize and maximize windows with the mouse wheel.
✅ Go to the beginning and end of the page with the mouse wheel.
✅ Scroll tabs with the mouse wheel.
✅ Switch between the last two windows.
✅ Maximize recent windows from the Taskbar with the mouse wheel.
✅ Activate an inactive window with a middle click.
✅ Move the window to the bottom of other windows.
✔️ Open a link in a new inactive window with a right and left click.
✔️ Open a link in a new active window with a left and right click.
✅ Mouse Gestures Collection ➰ for convenient and quick management of tabs and windows, close and restore tabs, windows, scroll through tabs. Gestures for - save, copy, paste, select all, select to the beginning, select to the end, open calculator, reload page, find, open the bar on the left, open the list of URLs, and others.
✅ Sticky Keys for a second (convenient typing, typing with one hand).
✅ Quick copy and paste.
✅ Erase all text on a line.
✅ Move the cursor to the beginning of the line. Move the cursor to the end of the line.
✅ Erase all text to the beginning of the line. Erase all text to the end of the line.
✅ Hotkey aliases (Pause button to open Magnifier. Switch between languages via Ctrl+F8, Ctrl+F9).
✅ Quickly shut down the computer with the Esc button.
✅ Fix Chrome browser bugs (Removing the message - To exit Full Screen press Esc).
✅ Scroll through pages in browsers by holding down the left or right arrow.
✅ Remember window sizes and positions on the screen.
✅ Hide/show desktop icons.
✅ Remove the window title.
✅ Make windows transparent.
✅ Always display the window on top of other windows.
✅ Disable the Win button (disable the Windows window from appearing when you press Win)
✅ Disable the Alt button.
✅ Disable Ctrl+Wheel zoom.
✅ Hotkeys for FileExplorer (hide/show the file bar on the left. Open file preview. Disable Ctrl+D).
✅ Hotstring (Quick print date and time, quick print email, print hyphens – —, print a line of pluses +++++++, minuses -------, equals ============ )
✅ AltTab window when hovering over the corner of the screen.
✅ Completely disable Taskbar (so it does not appear even when hovering over the bottom edge of the screen).
✔️ Fix corrupted video files.
✔️ Fix blocked fields rating, tags, comments.
✔️ Fixes the problem - the preview image is not displayed.
✔️ Change the preview image to another one, from another place in the video.
Install, check it out, leave comments, questions, and user experience.
Does it work on your computer, or does it not work?
This is tested on Windows 11 Home Edition.
What do you think about it.
If you do not use it, delete it, then why?
QuickHotkeys is a powerful, ready-made script collection that can easily handle tasks like moving and resizing windows from any place, dragging windows by tabs, and moving windows by clicking anywhere. Additionally, these tasks can also be accomplished using mshta scripts for lightweight and flexible automation. QuickHotkeys offers many productivity features pre-configured for instant use, saving time and automating common tasks without bugs—especially when run as Administrator. Check the YouTube playlist for tutorials and download from SourceForge. It’s a must-have for Windows users seeking convenience and efficiency.
