November 22, 2021—KB5007253 (OS Builds 19041.1387, 19042.1387, 19043.1387, and 19044.1387) Preview
Release Date:
11/22/2021
Version:
11/9/21
IMPORTANT
Because of minimal operations during the holidays and the upcoming Western new year, there won’t be a preview release (known as a “C” release) for the month of December 2021. There will be a monthly security release (known as a “B” release) for December 2021. Normal monthly servicing for both B and C releases will resume in January 2022.
10/12/21
IMPORTANT
Windows 10, version 2004 will reach end of servicing on December 14, 2021. To continue receiving security and quality updates, Microsoft recommends that you update to the latest version of Windows 10.
11/17/20
For information about Windows update terminology, see the article about the types of Windows updates and the monthly quality update types. For an overview of Windows 10, version 2004, see its update history page.
Note Follow @WindowsUpdate to find out when new content is published to the Windows release health dashboard.
Highlights​
  • Updates an issue that that causes some variable fonts to display incorrectly.
  • Updates an issue that might cause the 32-bit version of Microsoft Excel to stop working on certain devices when you export to PDF.
  • Updates an issue that displays letters or characters at the wrong angle when you use the Meiryo UI font and other vertical fonts. These fonts are frequently used in Japan, China, or other countries in Asia.
  • Updates an issue that causes Internet Explorer to stop working when using the Input Method Editor (IME) to insert elements.
  • Updates an issue that causes the Settings page to unexpectedly close after you uninstall a font.
  • Updates an issue that affects your ability to rename a file using folder view in File Explorer when you use the new Japanese IME.
  • Updates an issue that turns off screen capture and recording functionalities on the Windows Game Bar after a service failure.
  • Updates an issue that prevents the applications that you use often from appearing on the Start menu as they should.
  • Updates an issue that causes Internet Explorer to stop working.
