- Nov 5, 2018
- Thread Author
- #1
This topic was briefly brought up lately.
Myths and Misinformation:
An internal combustion engine is basically a heat engine, that is a coolish fuel and air mixture is drawn into the combustion chamber and then the piston rises in the cylinder and compresses the mixture. It is then ignited. The superheated burning mixture expands and this force drives the piston down in the cylinder. That lateral movement is converted into a rotary motion which then drives whatever.
So the issue is what can be done to optimize the fuel/air burn.
It was discussed a free flow exhaust enhances performance, well yes and no with qualifications.
Ideally you would expect a Stoichiometric reaction (in this case 14.7 parts air/1 part gasoline) would be perfect. No it's not for these reasons:
There was a saying among high performance motorcycle mechanics, "Lean is mean". Yes that's true for the most parts and here is why: Obviously you would want all the fuel to be burn to extract maximum energy from it. However that creates a problem for the motor, it's too hot and that drives exhaust gas temperature way up which accelerates engine wear. So ideally you would want a fuel/air mixture of around 14.2/1. That requires a fuel delivery that is very accurate across a wide RPM spectrum. Current electronic engine controls that very well. Back in my racing days we relied on reading spark plugs and adjusting jets size in the carburetors a black art.
Now what started this: A huge mistake car and light truck owners make is sticking loud free flow exhaust systems without any other changes. What happens is it knocks the fuel/air mixture way off driving the fuel/air mixture to the rich side typically 13.5 or less to 1. A rich mixture is the worst condition, it drives the combustion temperature way down which makes less energy available to drive that piston down into the cylinder bore. Not to mention it tends to wash the film of lubrication off the metal parts which greatly accelerates wear.
Want to know who messed up their car/truck with a off market exhaust? A gas engine's exhaust will smell like raw gasoline. A diesel engine's exhaust emits black sooty gas. In both cases what you see/smell is unburned fuel, what a waste not to mention what is burned is done to in an inefficient manner. All you have done is end up making a lot of unnecessary racket, I suspect in an attempt to draw attention on oneself. All it does in my eyes is prove how ignorant you are. In the US many states have passed laws that make these exhaust modification illegal not only for the vehicle owner, but the shop that did these modifications criminals.
In closing I remember there was a road circuit in Lime Rock, Ct (one of my favorites) that decided to enact a noise ordinance as the main races were held on Sunday. The emergence of the rotary engine (Mazda) and the horribly loud noise when it raced with an open exhaust system. Take my word for it, the noise was as bad as a jet blast. So this forced Mazda to equip the rotaries they raced with an exhaust system. Guess what they found? There was a measurable performance increase. That was extrapolated into all power plants and they found 4 stroke engines performance benefitted when the exhaust system had some back pressure.
So there you have it. Loud pipes do not increase performance unless there still is back pressure and the engine management chip is altered to reflect the exhaust system modifications. Factory exhausts are not explicitly all that bad.
