website stat Silent installs or baked serial | The Windows Forum
Regimus
Hi there, I am making autoruns for DVDs, CDs, applications etc. and I have made some bigger projects also that I have given away as I almost always do and my last one was called Recovery DVD 2012 but the guy renamed it to AIO Recovery tools 2012 and you can download it from a lot of trackers and it looks like this http://softarchive.net/blogs/downloaddownload/aio_recovery_tools_eng.976684.html or here http://iwannafile.com/search/AIO+Recovery/0/0
I have come to a little issue that maybe somebody can help me with, It is hard a lot of times to make an silent install (switchless) of an software and sometimes it is just impossible to do so I have given upp with that (almost)
I would like to know how to make a bach file or bat file to include the serial or the keygen into the software and that would be nicer for me because when I make an DVD with over 300 appz it would save me a lot of work and I dont have to make 2 buttons because of the software and the generator, keygen , serial etc. so I just have to put a button for the aplication and thats it and that would save a lot of time for me.
I know there is a lot of work to make an silent install of an aplication and sometimes it just dont work so if anybodyhas a very easy way to make that it would be even nicer to know.
Well thats it and I have not been here for a long time in the Thumper forum but here is some great reading in here, thanks.
Sincerely yours. Regimus
If you already know how to install with .bat files, you simply add /QUIET and it will become a silent install
Well I dont know anything about .bat files but everyone know how to make them just from a txt except writing text just write bat instead and thats my kloledge about .bat files :-)
Options;
Save as, not save.
Select All files from second drop down.
Rename the file to [name].bat.
Idk about batch files, but they usually start with @echo off
I'm sorry, I didn't mean to imply that, that's all I know unfortunately about batch files :(
Thats no problem, thanks for your reply...nice of you because a lot of people just jump over it even if they know the answear. Thanks again. /Regimus
If you'd like, i'll try dig something up on google for you about it, though silent installs through bat are very rare as far as i'm aware
Ummmm i hope this help's u little check this out nice Tool ....
http://windows7toolkit.49.forumer.com/viewtopic.php?f=6&t=25&sid=5ae9dfab1ff03aa546882ebbeee08ea9
