website stat Tame your workday with Microsoft Edge for Business | The Windows Forum
Go from chaos to calm with just a few clicks​
With countless projects, tabs, files and links to keep track of, it's easy for your workday to feel chaotic and overwhelming. And when your main work tool — the browser — is in this state of chaos, finding the right information becomes exponentially harder, resulting in frustration and lost time. How many times do you find yourself switching between tabs and applications every day? Think of how much time you're wasting each week when you have to hunt for the right tab each time! But there's a solution — using the right browser. With over 50% of time spent on a PC in the browser, it matters which one you choose. Microsoft Edge for Business is the fast and secure browser with productivity tools built in, to help you bring order and tranquility to your digital workspace. Its features help tame tab chaos and boost productivity — more than a well-organized spreadsheet. Keep reading to learn about some of these features and how to use them to manage your tabs, files and links more efficiently, bringing a sense of calm to your workday.
Organize your projects with Workspaces​
Want an easy way to keep your projects organized and separated? Try Workspaces! Workspaces enable you to create and save groups of tabs and files by project or topic, similar to how you would organize files in a file cabinet. You can name your workspace, add a color and an icon and customize it with the tabs and files that you need. And, if you're working on a project with others, you can even share the workspace with them, so your whole group can access the info in one place without having to send links back and forth. Workspaces auto-save too, meaning you can close them out and reopen them at any time, without losing any of your tabs. With all your tabs and files related to a project in one place, you can stay organized and stop wasting your time hunting for the right links.
Reduce clutter with tab groups​
If you ever have trouble finding the right tab among many open ones, tab groups are for you. Tab groups let you group related tabs together into a collapsible group and label them with a name and a color. With your tabs now neatly labeled, you can reduce clutter and distractions on your browser and quickly find the tab you need. Don't have time to make them? No problem! Edge for Business will do it for you by using AI to detect the common themes of your tabs and group them together. And you can easily customize them so they're just how you like.
Read your tabs more easily​
Are you someone who always has a lot of tabs open? If so, you know how challenging it can be to find the tab you're looking for among the chaos. Try vertical tabs! Vertical tabs enable you to view your tabs in a panel on the left side of your browser instead of horizontally at the top. This allows you to more easily read what the tab is and switch between them faster. You can also collapse or expand the vertical tabs panel to save space or see more details.
View two webpages at once with just one click​
If you're constantly switching back and forth between two tabs to compare information, split screen is for you! Instead of resizing and arranging your windows manually, split screen allows you to view two tabs side by side in the same browser window with just a couple clicks.
With these features and more in Edge for Business, you can control chaos, save time and enjoy a better browsing experience.
Get started today!​
