anyway to use 64bit aplication on 32bit system
amn
Aug 8, 2019
22
earth
Chrome 76.0.3809.100
is there anyway to use 64bit aplication on 32bit system. i can`t upgrade because my ram is 2gb
Windows 7
Probably not with 2GB RAM. Is there anyway to upgade the RAM in your system? Pretty much 8GB is considered the normal for later versions of Win 10 while 4GB considered the minimum for smooth operation for all other versions
amn
Aug 8, 2019
22
earth
i tried thumpers window 10 64bit from tpb first but that operated bit slowly, now installed 32bit again and its somehow good
32bit running nice, just a single software demands 64bit
Windows 7
There are emulators available that allow you to run a virtual 64 bit environment in Windows. IF you could get one to load given your limited resources the performance would be so slow it would be unusable so the practical answer in your case is no.
Sorry.
  • Like
Reactions: amn
jamvaru
Jun 23, 2012
72
Edge 18.17763
ram is really cheap
try ebay for some used stuff
but avoid the 'registered' ram, check the details on the web to be sure
which program requires 64bit? is that one program really necessary? is there an alternative program that will do the same thing?
amn
Aug 8, 2019
22
earth
Firefox 68.0
ram is really cheap
surely but it was photoscapex, got alternative now
  • Like
Reactions: jamvaru
