AutoData 3.45 problem error sentinel key not found.
AUDIA42.0TDI
I download Autodata 3.45 from PTB and follow all steps , and i have error with start SENTINEL KEY NOT FOUND.
Please HELP , sory for bad ENGLISH.
I'am from BOSNIA,
I have heard this program will only run successfully on Windows XP. I am not sure if that's true but you might want to try that. The off-line version data is getting very old so it makes sense that no group will update the program.
If your current AutoData setup doesn't work try a different setup or downgrade by searching for a lower version. There is plenty of torrents for that software and i don't think that is required to have AutoData 3.45 to fully take advantage.
When we have compatibility issues usually Vista Service Pack 2 works. Honestly some of the best drivers are Vista Service Pack 2.
