website stat driveri za printer hp laserjet p1006 | The Windows Forum
babalu
Molio bih kako da aktiviram navedeni pisač na windows 10, na službenim stranicama nema drivera za pisač
If there is no official driver available for this printer on Windows 10, you can try the following solutions step by step:
  1. Automatic driver installation by Windows
    Connect the printer to the computer (via USB or network), then:
    • Go to Settings
    • Devices
    • Printers & scanners
    • Click Add a printer or scanner
      Windows 10 may automatically download and install a compatible driver.
  2. Use an older driver in compatibility mode
    If a driver is available for Windows 7 or Windows 8:
    • Download the driver
    • Right-click the installer and choose Properties
    • Go to Compatibility
    • Enable Run this program in compatibility mode and select Windows 7 or 8
    • Run the installer as administrator
  3. Manual installation (Generic driver)
    In Printers & scanners:
    • Click The printer that I want isn’t listed
    • Choose Add a local printer or network printer manually
    • Select the correct port (USB or TCP/IP)
    • From the manufacturer list, choose Generic or Microsoft
    • Try Generic / Text Only or a similar compatible driver
  4. Windows Update driver list
    While adding the printer, click Windows Update and wait for the full driver list to load.
  5. Contact the manufacturer
    If none of the above works, it’s best to contact the printer manufacturer’s support. They may provide an unofficial or alternative driver.
I have an old HP LaserJet 1320nw that works great so I am not ready to give it up. I am able to use this printer on my home network without a problem using this driver. I think HP has this driver available for the older hardware, it truly is a universal driver. You may not have all the features you once had, but your P1006 should work fine.
Install this driver first then connect the printer. Windows may find this driver on it's own, if not, when installing the driver, remember the folder where it lands. Works great for Windows 11 too.
The driver is : upd-pcl5-x64-6.1.0.20062
Find it here: https://support.hp.com/us-en/drivers/hp-universal-print-driver-series-for-windows/model/503519
Welcome babalu.
This board communicates in English if you don't mind.
Imam stari HP LaserJet 1320nw koji radi odlično, tako da ga se nisam spreman odreći. Mogu koristiti ovaj pisač na kućnoj mreži bez problema koristeći ovaj upravljački program. Mislim da HP ima ovaj upravljački program dostupan za stariji hardver, to je zaista univerzalni upravljački program. Možda nemate sve značajke koje ste nekad imali, ali vaš P1006 bi trebao raditi dobro.
Prvo instalirajte ovaj upravljački program, a zatim spojite pisač. Windows bi mogao sam pronaći ovaj upravljački program, ako ne, prilikom instalacije upravljačkog programa zapamtite mapu u kojoj se nalazi. Izvrsno radi i za Windows 11.
Upravljački program je: upd-pcl5-x64-6.1.0.20062
Pronađite ga ovdje: https://support.hp.com/us-en/drivers/hp-universal-print-driver-series-for-windows/model/503519
Dobrodošao babalu.
Ova ploča komunicira na engleskom, ako vam ne smeta.
Hvala na pomoći,ali kod mene to ne radi.ne mogu instalirati te drivere.Instalacije krene i nakon par sekundi stane.lp.
Dobrodošao babalu.
za ovaj printer nema podrške
Poštovani! Zahvalio bih se na vašem trudu da mi pomognete.Drivere skinem sa navedenog linka ali se neda instalirati.Uspio sam pokrenuti pisač u načinu kompatibilnosti za windows 7 lp
