My two WD Elements hard disks keep disconnecting while I render video with Adobe Premiere and DaVinci Resolve. I am worried because, a part from not being able to work on them, if I don't disconnect them, they will get damaged, with time.
They are connected to the pc with a USB 3.0 Hub which has its own power supply, and both of the HD have their own power supply.
With the same configuration but another older pc with windows 7, it was no problem, now that I have my brand new pc, this happens.
In case you wonder, I already set to high performance the power options in the control panel, preventing selective usb deactivation.
I also tried to connect my pc to another power plug in the house, in case the problem was not enough power routed by my multiple plug, where I have the pc, the 2 hard disks, the hub and 3 monitors, with no different results. iphone 15 ringtone
My system specification:
CPU: AMD Ryzen 3900x (with BeQuiet! Dark Rock Pro 4)
Motherboard: Gigabyte Aorus Pro x570 (non wifi)
Graphic card: Gigabyte RTX 2060 Super Gaming OC 3X rev. 2
PSU: Corsair RM 850
6 Noctua fans
Audio card: external Focusrite Scarlett Solo I
Storage:
2 external WD Elements HD 5 TB + 4 TB
1 external Toshiba HD 2 TB
1 internat Seagate Barracuda 8 TB
1 NVME Samsung 1 TB
OS: Windows 10 Pro
download ringtone samsung
PSU: Corsair RM 850
6 Noctua fans
Storage:
1 NVME Samsung 1 TB
OS: Windows 10 Pro
