Since 2010 · Windows 11 · 10 · 8 · 7
Over 15 years of helping Windows users worldwide. Ask questions, share tips, download resources and connect with the community — free and always friendly.
SignUp Free Already a member? Log in
  • Private messages
  • Exclusive guides & downloads
How to fix WHEA_UNCORRECTABLE_ERROR
How can I fix a When Correction error?
1. Disable overclock in BIOS
Press Windows Key + I to open the Settings app.
Go to Update and Security.
Navigate to the Recovery tab. In Advanced Startup, click Restart Now.
On Advanced Startup, go to Troubleshooting, then go to Advanced Options.
Select UEFI Firmware Settings. Click Restart.
After the computer restarts, it will automatically open the BIOS, so go to the Advanced tab.
Navigate to the display and watch for overclocking.
Make sure overclocking is disabled.
Save changes to the BIOS (by pressing F10 on your keyboard), and restart your computer normally.
If you're having trouble following these solutions, visit our guide on how to access the BIOS for detailed instructions and alternative methods.
Overclocking can cause a correction error, so if you are using overclocking software, be sure to disable it.
2. Check if there is a hardware problem
Press Windows Key + X and select Windows PowerShell (admin).
Now run the following command: chkdsk / f C:
Press Y to schedule a restart.
Restart your PC and wait for the scan to finish.
When correction error is often caused by SSD issues so we suggest using specialized BSOD repair software like Restore to fix it.
3. Run Windows Memory Diagnostics
Press Windows Key + S and type memory. Select Windows Memory Diagnostic.
Select Restart now and check for problems.
If you find a stop along the way, such as checking a hard drive with errors, try replacing the memory.
If you suspect that there is an additional problem with the hardware, we suggest using hardware diagnostic software to find the cause.
4. Update your drivers
Press Windows Key + X and select Device Manager.
Find the driver you think is causing the problem, right-click on it and select the update driver.
Automatically select a search for drivers and wait for the process to finish.
Repeat this for all drivers you hold responsible for this problem.
Drivers cannot repair BSOD wheels so it is important to keep them up to date.
Manually updating drivers can be a tedious process, especially if you need to update many of them, but you can speed up the process by using driver update software.
6. Uninstall the problematic Windows Update
Now go to the Update and Security section.
Click View Update History.
Now click on Uninstall Updates.
A list of updates will now appear.
Double click on a specific update to remove it.
According to users, sometimes an unreliable error can appear due to problematic Windows updates. For more information, visit our Guide to How to Remove Failed Windows Updates.
7. Disable the Turbo Boost feature in the BIOS
Restart your PC and press F2 to enter the BIOS.
After entering it, look at the Turbo Boost option.
Disable it and save changes.
Note mark
We suggest checking your motherboard manual to see how to find this feature.
8. Disable additional audio devices
Press Windows Key + S and enter the sound. Now select Change System Sound.
When the Sound window opens, go to the Playback tab. Right-click on each non-default audio device and select Disable.
Repeat the same steps for all recording devices.
After that, apply to save the changes and click OK.
Some users are also recommending disabling additional audio devices from Device Manager. To do this, follow these steps:
Find your audio devices and disable all devices except your default device.
To disable a device, just right-click on it and select Disable device from the menu.
Click Yes when the confirmation message appears
Whea_Unrectable_Error Overclock
According to users, your audio device may cause unexpected error messages to appear. To fix the problem, you need to find and disable additional audio output and input devices.
After disabling all non-default devices, the problem should be solved.
How can I fix an incredible error on Windows 11?
Use System Restore
Press Windows Key + R and type stud.
Now click on Next to proceed.
Select the desired restore point and click Next.
Follow the on-screen instructions to complete the process.
If the problem is still there, here are more solutions to fix the incredible bug in Windows 11 once and for all.
