DwightSchrute
- Feb 1, 2022
- 9
- 3
- OS
- Windows 10
- BR
- Chrome 103.0.0.0
Can we extend the expiration date of the license?Yup, you are right, i used same method![]()
Nope, 2030 is just fine for me.Can we extend the expiration date of the license?![]()
Awseome that it worked for youYup, you are right, i used same method![]()
LINK REMOVEDAwseome that it worked for youHoy es una dia de divertida..jajajaja.
Could you share the key generator you're using?
Using version 9.2.5 and now my server wont send any mail.
I am using version 9.4.1 patch 1 with the same keygen. It works (until 2030-11-19)Hello, can somebody help me with this...
So want to step up to the latest version, but the keygen doesn't work (which was included in 9.2.9)
Any suggestions?
2030, plenty of time.Hi, Why the Kerio Conect 9.29 license expires in 2030? Whats about after?
I haven't test with v10 yet...Hello, and first of all thank you for this keygen! It seems that this keygen also works with the latest version of Kerio Connect (10.0.0). You confirm ? Someone has already tested ?
Unable to benefit from anti spam with the keygen?
Why in the explanation of the keygen, it is not recommended to disable "Virus update disable" and "Install auto virus update"?
thanks!![]()
Thanks!It works:
It depends how it was cracked. Sometimes a extension in the license means End of Cycle for the program.Hi, Why the Kerio Conect 9.29 license expires in 2030? Whats about after?
Click "OK"Thanks!
Yes, it also works for me! Just an error message "Unable to open file """ when I patch in the keygen (version 1.1.0.58). Do you also have this error?
I don't use antivirus for kerio connect.HI I am getting this error with the antivirus any ideas? version 10 using the keygen from version 9.2.9.
I have updated the definitions using the update bat here:
BitDefenderManualUpdate – Google Drive
drive.google.com
AntivirusModule.cpp: Antivirus Server error(0): Version info doesn't contain required location.
AntivirusModule.cpp: Antivirus update failed: Version info doesn't contain required location.
Thanks
