Malwarebytes Premium 3.0 FINAL
formigalx
Hello
I can´t activate the premium version.
I have folowed all the instructions, i have tried more then one time, it just dont work, it gets the free version.
The first problem i encountered is after i execute the first setup, i trie to go to"C:\ProgramData\Malwarebytes\Malwarebytes Anti-Malware\Configuration" but i have no "configuration" folder.
I copy the licence file to "C:\ProgramData\Malwarebytes\Malwarebytes Anti-Malware", but it just don´t work.
Can anyone help me please? :crying:
- Instructions -
* If you have a previous version activated to Premium using any keygen, remove it completely, particulary make sure you totally delete the following path:
Delete this folder! Also make sure to clean registry leftovers. Afterwards reboot.
* Enable internet connection, this workaround will work in online environment.
* Edit the hosts with the following before doing any setup:
0.0.0.0 keystone.mwbsys.com
Hosts is located in: C / Windows / System32 / Drivers / etc folder. Run hosts with notepad and add the above line there and save it.
* Unpack and execute " 1.Setup.exe " first.
* After installation is done, don't launch it.
* Copy the License file in the following path:
* Confirm replacing. Still don't launch Malwarebytes!
* Now, execute " 2.Setup.exe " and let it overwrite previous installation.
* Now you can launch the application. It will automatically pick up the existing Premium subscription.
Tested on Windows 7, Windows 8.1 and Windows 10.
Tested by setting system clock 1 year ahead, no issues have been met.
Tested by enabling and applying updates, no problems are encountered.
Don't do the following:
* Don't directly install v3 setup and try activating it, it will NOT work.
* Don't use a v2 Premium subscription on the version 3 setup.
Tiny Notes:
* On dashboard it says updates are the most current, however it already checks and applies updates. You can test it unactivated Free version, too the same bug there too.
* Even though this is the stable / final release the developer also confims that it includes bugs to be fixed over the next year. If you're not happy, don't use the product.
You can always thank us here: http://www.TechTools.ME / http://www.ThumperDC.com
8,910
Re: Malwarebytes Premium 3.0 FINAL + Crack [TechTools]
<t>Install 1st setup then copy and replace licence file then install setup number 2.<br/>
<br/>
It works just fine.</t>
formigalx
<t>i execute the first setup, i trie to go to"C:\ProgramData\Malwarebytes\Malwarebytes Anti-Malware\Configuration" but i have no "configuration" folder.<br/>
Where do i replace the licence?</t>
Wallcrawler
<t>I have followed all your steps. I have found all the folders to be deleted and then swapped the correct file and it is only giving me the free version. Your patch is not working. I have modified the Host file as well. This is all as it is suppose to be but it does not work. Do you have any ideas...other than paying, of course?</t>
8,910
<r><QUOTE author="Wallcrawler"><s>
Wallcrawler said:
</s>I have followed all your steps. I have found all the folders to be deleted and then swapped the correct file and it is only giving me the free version. Your patch is not working. I have modified the Host file as well. This is all as it is suppose to be but it does not work. Do you have any ideas...other than paying, of course?<e>
</e></QUOTE>
<QUOTE author="formigalx"><s>
formigalx said:
</s>i execute the first setup, i trie to go to"C:\ProgramData\Malwarebytes\Malwarebytes Anti-Malware\Configuration" but i have no "configuration" folder.<br/>
Where do i replace the licence?<e>
</e></QUOTE>
<br/>
<br/>
Hi,<br/>
<br/>
First, extract MBAM-CleanUnstall.rar , then run as administrator, unistall malwarebytes, ristart your machine, then edit hosts file, install 1st setup (do not open it), copy and replace licence file then install second setup.<br/>
<br/>
It should work, i just tested again it on win10 x64 PC.</r>
BSullivan72
Hi am I supposed to disable updates for my malwarebytes?? Or will it update at all because I placed 0.0.0.0 keystone.mwbsys.com in the host file??
8,910
Feel free to update it :)
tutoy2002
Update not working. Keeps checking but not updating. Followed all your instructions. Windows 10 x64
CPUjohn
Get identical problem, had same issue with old 2.x premium when upgraded to 3.0
Steps I took: Uninstalled 2.x premium through Win10, deleted \ProgramData\Malwarebytes directory, Ran cleaner, rebooted, Double checked HOSTS file for entry, Ran Setup1, copied licence file, ran Setup2 which automatically loaded app, DOES NOT UPDATE correctly. Shows as 3.0.4 Premium, just doesn't update.
Thanks, John
Win10 (x64)
thegame1322
Malwarebyte's updated something on their back-end about a week ago where it will not update the package version (definition updates/rules) if keystone.mwbsys.com is blocked in the hosts file.
There needs to be a new crack that bypasses this.
Thread starter Title Forum Replies Date
J I need help installing the premium version of Malwarebytes. Windows 8 and 7 Help and Support 1
DVDR_Dog qBittorent and MalwareBytes Virus, Trojan, Spyware, and Malware Removal Help 5
DVDR_Dog Malwarebytes Browser Guard becomes the Ethics Police Anti-Virus, Anti-Malware, and Privacy Software 5
S Malwarebytes 3.0 Worked But Didn't? Windows 8 and 7 Help and Support 8
ThumperTM Malwarebytes' Anti-Malware [Freeware] Anti-Virus, Anti-Malware, and Privacy Software 6
S Avast Cleanup Premium Windows 8 and 7 Help and Support 2
N Downgrade: Change Windows 7 Ultimate to Premium or Professional Tutorials 1
N Need serial number for ChrisTV Online Premium Edition 6.80 ! Windows 8 and 7 Software Chat and Support 1
Buu Google Chrome Premium Cookie Injector- 1.3 Tutorials 2
D How to Download In Direct Link Without Premium Acc and Free Tutorials 2
Teebagger KMSpico 10.1.8 FINAL + Portable installing issues Windows 10 Help and Support 21
P Wondershare Video Converter Ultimate 10.0.7.97 FINAL question Windows 10 Help and Support 1
F Wondershare Video Converter Ultimate 10.0.7.97 FINAL + Crack Windows 8 and 7 Help and Support 1
M having trouble with KMSpico 10.1.8 FINAL Windows 8 and 7 Help and Support 2
J KMSpico 10.1.8 FINAL+Portable issues Windows 8 and 7 Help and Support 0
C HELP HOW TO USE KMSpico 10.1.8 FINAL Windows 8 and 7 Help and Support 3
D Nero Burning ROM 2017 18.0.00800 FINAL [TechTools] "activation required" Windows 8 and 7 Help and Support 1
D KMSpico 10 2 0 FINAL - Windows(R) Education - not working Windows 8 and 7 Help and Support 0
K Revo Uninstaller Pro 3.1.8 FINAL Windows 10 Help and Support 10
J KMSpico 10.2.0 FINAL not working Windows 8 and 7 Help and Support 8
H Nero 2017 18.0.0080 FINAL: getting the extra parts? Windows 8 and 7 Help and Support 4
A C:\software downloads\Nero Burning ROM 2016 17.0.00700 FINAL [TechTools.NET]\Nero Burning ROM 2016 1 Windows 8 and 7 Software Chat and Support 0
L DVDFAb.9.2.2.8 Final Windows 8 and 7 Help and Support 4
T ~Broken~Wondershare Data Recovery 5.0.0.5 FINAL + Crack Windows 8 and 7 Help and Support 7
ThumperTM Windows 10 FINAL Keyboard Shortcuts Windows 10 Tutorials 2
ThumperTM How to Install Windows 10 FINAL on Your PC Windows 10 Tutorials 25
T nero 2015 burning rom final Windows 8 and 7 Help and Support 1
0 DvdFab v9.2.0.0 FINAL Windows 8 and 7 Help and Support 3
T Nero Burning ROM FINAL 2015 v16.0.02200 Windows 8 and 7 Help and Support 4
A step up 2 THE streets -final dance Youtube Music & Videos 2
B DVDFab 8.1.8.5 Qt Final Incl. Crack [ThumperDC] Windows 8 and 7 Help and Support 9
C Newbie Needs Help with AnyDVD 6.7.7 Final + Register Key... Windows 8 and 7 Software Chat and Support 5
79
81
