website stat Need help patching photoshop | The Windows Forum
qvoRlx
Activity Log
GenP Version: 3.6.9 - CGP
Config Version: 3.6.9 - CGP
10 File(s) were found in 4 second(s)
Checking File: dvaappsupport.dll - using Custom Patterns
Searching for: TeamProjectEnabler: 488379????740A488379????7403B001C332C0C3
Searching for: TeamProjectEnabler2: 488D4B08FF15??????004885C07408B0014883C4205BC332C04883C4
Replacing with: 488D4B08FF151A1625004885C07408B0014883C4205BC3B0014883C4
C:\Program Files (x86)\Adobe\Adobe Photoshop 2026\dvaappsupport.dll
File patched by GenP 3.6.9 - CGP + config 3.6.9 - CGP
MD5 Checksum: 0x1AB24DDB48C3EED087FCB489074FCEDE
Checking File: Photoshop.exe - using Default Patterns
Searching for: Banner: 72656C6174696F6E7368697050726F66696C65
Searching for: Banner2: 000000000000000072656C6174696F6E
Replacing with: 000000000000000078656C6174696F6E
Searching for: CmpEax61: 8B??85C074??83F80674????83????007D
Searching for: CmpEax62: 8B??85C074??83F80674????83??????007D
Searching for: CmpEax63: 8B????85C074??83F80674????83????007D
Replacing with: C743200300000083F806740048837B5800EB
Searching for: CmpEax64: 8B????85C074??83F80674????83??????007D
Searching for: Good1: C7????????????1045????45????33??48????????????FF15
Replacing with: C7442420010000004533C94533C033D2488D0DA8C52B04FF15
Searching for: Profile1: 00007504488D4850
Replacing with: 00007500488D4850
Searching for: Profile2: 00007504488D5050
Searching for: ProfileExpired1: 85C075??????????75??B892010000E9
Searching for: ProfileExpired3: 85C075????????75??B892010000E9
Searching for: ProfileExpired4: 488D4D??483B??0F??????000048????4889??4885C9
Searching for: ProfileExpired5: 488B0B4889034885C974??BA04000000E8????????B00148
Searching for: ProfileExpired6: E8????????????????4885C974??BA04000000E8????????4C8D5C
Searching for: ProfileExpired7A: 75??8D4E18E8????????4889442420488BD04885C00F84??050000
Searching for: ProfileExpired7B: 75??8D??18E8????????488BD048894424384885C00F84??040000
Replacing with: 66908D4B18E8FF6DF9FA488BD048894424384885C0660F1F440000
Searching for: ProfileExpired7C: 75??B918000000E8????????488945C0488BD04885C00F84??050000
Searching for: ProfileExpired7D: 75??8D4E18????????????488BD048????????4885C00F84??050000
Searching for: ProfileExpired7E: 75??8D4F18E8????????48894424200F57C00F1100C7
Searching for: ProfileExpired8A: 00C740??01000000??????????????488908C740109201
Replacing with: 00C7400C01000000488D0D33A57502488908C740100000
Searching for: ProfileExpired8B: 00C740??01000000????????????01488908488D4810C7019201????????????????????????????????0F84
Searching for: ProfileExpired8C: 75??8D4F18E8????????0F57C00F110048????????????48890848??????C70192010000
Searching for: ValidateLicense1: 83F80175??BA94010000
Searching for: ValidateLicense2: 83F8040F95C281C293010000
Replacing with: 83F8040F95C2BA0000000090
Searching for: ValidateLicense3: 83F8040F95C181C193010000
C:\Program Files (x86)\Adobe\Adobe Photoshop 2026\Photoshop.exe
MD5 Checksum: 0x7709E9EF54664F7892DE5580C64C13FC
C:\Program Files (x86)\Adobe\Adobe Photoshop 2026\Required\DynamicLinkMediaServer\dvaappsupport.dll
MD5 Checksum: 0x13931C2C3A3DD62C95169423781B5C51
Checking File: RuntimeInstaller.dll - using Custom Patterns
Replacing with: C7442420010000004533C94533C033D2488D0D4F072900FF15
C:\Program Files (x86)\Adobe\Adobe Photoshop 2026\Required\DynamicLinkMediaServer\RuntimeInstaller.dll
MD5 Checksum: 0x3CFF8E85126E948B82531CDB9A19E60C
Checking File: SweetPeaSupport.dll - using Custom Patterns
Searching for: HevcMpegEnabler3: FF50??0FB6
Replacing with: FFC0900FB6
Searching for: HevcMpegEnabler4: FF50????0FB6
Replacing with: FFC090400FB6
C:\Program Files (x86)\Adobe\Adobe Photoshop 2026\Required\DynamicLinkMediaServer\SweetPeaSupport.dll
MD5 Checksum: 0xA94024DCD71A10BDAFE25F31CA3E4CE3
Checking File: 4.js - using Custom Patterns
Searching for: JS5: 52656C6174696F6E7368697050726F66696C65
Replacing with: 58656C6174696F6E7368697050726F66696C65
C:\Program Files (x86)\Adobe\Adobe Photoshop 2026\Required\UXP\com.adobe.ccx.start\js\4.js
MD5 Checksum: 0x4B133FF486FA5C7DD5D3769E1E132266
Checking File: manifest.json - using Custom Patterns
Searching for: Version1: 6363782E7374617274222C0A20202276657273696F6E223A2022??2E
Searching for: Version2: 6363782E7374617274222C0A20202276657273696F6E223A2022????2E
Replacing with: 6363782E7374617274222C0A20202276657273696F6E223A202231322E
C:\Program Files (x86)\Adobe\Adobe Photoshop 2026\Required\UXP\com.adobe.ccx.start\manifest.json
MD5 Checksum: 0x4AD70D8DE9F18BFF903582EE7363AECD
I was able to run the patch but after running and opening photoshop, it shows that the application is not licensed. That means the patch failed. Please help. affatched above is the log I copied from the patch file after running the patch
