website stat Problems after security update | The Windows Forum
Kpolluk
After a security update tonight everything on the right side of my taskbar is just gone. I've tried some fixes I've found online and nothing has worked so far.
What I've tried:
-Restarting my PC
-Going into my task bar settings and turning the menu on and off again
-Restarting Windows explorer.
-Ran SFC & DISM Scans
OS build:System->About also crashes same for trying to go to settings->app settings to repair
The update was 2026-06 Security Update (KB5094126) (26200.8655)
It is ungrateful to give any advice at this distance because it all depends on how your OS is configured. The installation of updates depends on the Windows configuration. For some, they pass without problems, and for others, problems arise. The only thing is to try to uninstall it and see if you have System Restore or a Windows backup and restore it.....You can try this as in the picture. My version of Windows is different. 26H1 Although I also had a problem with the installation of the latest patch, but I fixed it using Macrium OS backup.
