Reboot and Select proper Boot device
markophillips
Chrome 87.0.4280.141
Hello,
So i have this problem that started when i was adding ram to the pc. When ever i turn my pc on this message appears "Reboot and Select proper Boot device or insert Boot Media in selected Boot device and press key". I tried to fix it and found it helpful if i hit the pc from the side then it turns on but only boots for a while then it shuts down again. Can someone help ?
569
Chrome 88.0.4324.104
It sounds like you may have caused a problem with the connection between the hard drive and the mobo. That would explain why the banging temporarily fixes the problem. Check the SATA cable and try a spare if you have one. There is an outside chance it's the new RAM but I doubt it would be intermittent but reseating the memory modules while the case is open won't hurt. Finally try resetting the BIOS. Check your manual, its either pushing a button on the board or removing the CMOS battery for 20 seconds or so.
My money is still on a bad HD cable or loose connection but you never know.
Snuffy
Dec 10, 2011
70
20
Firefox 85.0
usually that also means that your BOOT.ini or BCD is damaged. and many times a BIOs reset will fix, if not then boot to Command as admin and reset your Boot Device with BCDEDIT.
82
83
