website stat AutoData 3.45 | Page 2 | The Windows Forum
AutoData 3.45
[quote="Barry George Stevens" post_id=100093 time=1518481091 user_id=162826]
Sorry to jump on your thread, but how did you sort this in the end. I have tried to run on Windows 10 (32) and Windows 7, but constantly get the Sentinel Key error on attempting to start program. All steps followed with no issues!!??? Any help appreciated!!
[/quote]
on windows 7 did you install the emulator? and run as admin? and did the drivers instal? for the record you do not need to install the emulator in windows 10.
Hi All, I'm trying to get the Keygen for a 32 bit system there is no keygen for that that only a 64 bit system. So i cannot carry on with the installation without the keygen step. is there anyone who can assist.
I have it here, folder name GetUid-x32
I have installed AD a few times now mostly on 32 bit systems
PM your email address and i will send it over :ok:
I'm a bit late but didn't see replies for a while. Thanks thumper n team. Now I just need to find a good copy of windows 7.
Where can I find the ISOs of the different vehicles? I had them before but they disappeared along with my laptop when someone decided to "borrow" it without my permission and without giving me a return date. (My home was burglarized if you are too dense to figure that out on your own.)
Hi can anyone please help me with this errorView attachment 4971
Just go back and have a look through this entire thread. You may have a bad download, it happens. I think you need Windows 7 as well. Use an uninstaller (Revo portable is free. Do a search) Delete all the directories left behind before you attempt another install. Kind of generic steps but they usually work. I think the answer is already in this thread if you read it.
same issue as
Freddie
how go you go about changing the reg file to delete the hw id
This program will not run with Windows 10. That dongle crack isn't as easy as you think. It's been a long time since I tried to reverse engineer that crack and it was some brilliant work, not some one-liner fix. No one is going to take the time to port it to Windows 10 since the data files are quite old and it's on-line only now. It's a fresh install of Windows 7 that hasn't been fooled with. A failed attempt to install this is usually fatal to future tries.
The only installs I have seen in a couple of years are dedicated stand-alone systems with big-ass hard drives to hold all the Data ISO's I don't think they even go on-line with them.
thank you! i will try a few things with a windows 7 pc i have. I appreciate the fast response!
Thank you a lot andy0pandy. I have been tinkering around this install for like 6, 8 hours already.
It works like a charm.
Now, the only doubt I have is, that I did not know that autodata has dates only up tp 2014. I would like to know how can I get the latest years of if there are non existen and I have to go autodata online? Is there a way to get the next years, up to 2019?
Thanks for your hard work everyone.
2014 is last version you can get for free.
Ok, so by going beyond, I'm locked behind $$$ from Autodata. Is that correct?
Thanks for being so quick.
Not sure if i understand you good, versions newer than 2014 can't be found for free, you will need to pay autodata if you want to use newer version, you don't need to pay us (TheWindowsForum) anything, all we do, we do it for free. Share is caring :)
If you had taken the time to read the post that took me far more time to compose than to read it clearly states that Autodata is available on-line only since 2014 and that's the reality of that program. No members of this board make a dime on anything posted here. Those are the rules. We do it for our community and our love of the subject.
Thumper pays for this board to exist so if you would care and contribute to help pay to keep this board running as I and others have done we all would be grateful.
Thanks
Hey I ran across some very old notes from who knows when.
You might try a search for "Autodata Runtime error 217 at 004bb10d Windows 10/7/8/XP" video and see if that helps. Sorry I forgot all about that it was so long ago. I don't use that program. I haven't turned a wrench for a long while since I no longer have a place to work on my cars.
Hola, necesito una mano, me quedaré en el paso 4
al momento de generar el UID siempre me sale el codigo 6400000000 y antes el mensaje "requiere privilegios de administrador" ya le da permiso total a la carpeta también reiniciar el equipo varias veces y me sigue saliendo lo mismo, el codigo no cambia de 6400000000, hay alguna solucion? o otra forma de hacerlo
gracias
uso win 10 64 bit
[QUOTE = "ThumperTM, publicación: 114429, miembro: 2"]
Google "AUTODATA 3.45 FULL [TechTools]"
[/ CITAR]
en lace roto alguna sugerencia mas
