AutoData 3.45
Here my following solution:
  1. Open cmd as Admin and paste this--> regsvr32 /s C:\ADCDA2\ChilkatCrypt2.dll
  2. Open "Keygen" folder and Run "GetUid-x86" or "GetUid-x64" as Administrator (<<< this is important) depending on your OS (32 or 64 bit)
  3. Now because you have your UID number you can run "keygen.cmd" and paste/enter it to generate "license.reg" registry file (it's important to NOT enter first 2 digits which are probably 64, enter ONLY last 8 digits)
  4. Run new generated registry file named "license.reg"
  5. Start the program...If you get the error Exception EconvertError in module ADBCD.exe at 0041FE6A ""10/06/2009" is not a valid date" ---> change the windows region settings to us
Can you help me i have a problem with autodata i follow the steps to instal but when i run it i have some error
Error E0226 -- Sentinel key not found​
AUTODATA INSTALLATION INSTRUCTIONS:
*IMPORTANT* BEFORE YOU BEGIN READ THIS NOTES:
- Run as Administrator is very important where it says "(<<< this is important)"!
- Every restart/reboot is MUST and IMPORTANT for Windows 7/8/8.1/10 but NOT for XP!
- User Account Control (UAC) must be disabled when running DSEO (dseo13b.exe)!
- If you get error on Autodata starting like in picture included in this package, you'll need to change your Regional settings to English US!
- If you get any kind of error trying to start Autodata, go to "RegSettings" folder and first run "DeleteRegSettings.reg" then "RegSettings_x86.reg" or "RegSettings_x64.reg" depending on your OS (32 or 64 bit)!
- If you want to remove "Test Mode" label from screen you can do it either from DSEO (dseo13b.exe) or visit link below and do it by Microsoft official way:
https://support.microsoft.com/en-us/kb/2509241
1. Run "Install_x86" or "Install_x64" depending on your OS (32 or 64 bit)
2. Follow on console screen messages and wait for the installation to complete
* Windows 7/8/8.1/10 users MUST do following "a-i" steps while XP users should skip to step 3 *
a) Disable UAC
b) Restart/Reboot your PC
c) Disable Antivirus because the next step is false-positive (NOT virus)
d) Run "dseo13b.exe" as Administrator (<<< this is important) - Enable Test Mode
e) Restart/Reboot your PC (after restart/reboot "Test Mode" will be shown on screen)
f) Disable Antivirus again
g) Run "dseo13b.exe" as Administrator (<<< this is important) - Sign a System File
It's best to find your own path but depending on your OS it should be:
32 bit = C:\Program Files\nodongle.biz\AuDaS0\AuDaS0.sys
64 bit = C:\Program Files (x86)\nodongle.biz\AuDaS0\AuDaS0.sys
...and wait for confirmation message
h) Exit from DSEO (dseo13b.exe)
i) Restart/Reboot your PC (those "a-i" steps are for signing emulator, NOT needed for XP)
j Open cmd as Admin and paste this--> regsvr32 /s C:\ADCDA2\ChilkatCrypt2.dll
3) Open "Keygen" folder and Run "GetUid-x86" or "GetUid-x64" as Administrator (<<< this is important) depending on your OS (32 or 64 bit)
4) Now because you have your UID number you can run "keygen.cmd" and paste/enter it to generate "license.reg" registry file (it's important to NOT enter first 2 digits which are probably 64, enter ONLY last 8 digits)
(in case your UID is 6400000000 you must restart/reboot your PC and go back to step 3 because that UID is NOT proper and valid)
5) Run new generated registry file named "license.reg"
6) Start Emulator as Administrator (<<< this is important) from Start menu or from installed directory which is probably something like C:\Program Files\nodongle.biz\AuDaS0 and there is a file named "ndStart.cmd" or "ndRestart.cmd"
7) Open "Autodata 3.45" from desktop shortcut or ofcourse C:\ADCDA2\ADBCD.exe
(Any kind of errors related to NOT successfully registered .reg files? Just register them manually from "RegSettings" folder as described at the beginning of this text (before all this steps))
8) Enjoy!
well i get error on generate the licenckey and i follow the instrucion, i try to install on Windows Xp same error like windows 7 32bit and windows 7 64bit
And what exactly is the error you are seeing?
We can't read minds here just yet. Google Assistant is working on it but nothing yet. ;)
Hello, sorry this might sound a bit repetitive but i'd like to know if it's completely impossible to run autodata 3.45 on windows 10?
I've tried a couple of times and unfortunately once I reach step 4 to generate the reg file, it just doesn't work. I've also noticed I'm unable to find the directory created in step 2.g) when I search for it.
Thank you in advance
Hi guys,
I am getting this error, any advice please ??
Windows 10? Read the entire thread.
I have the same problem with the getuid. I've done everything in this thread and I still get 6400000000.
I'm aware this is a very old post, but just installed Autodata 3.45 on a new Windows 11 PC (Some people are still using it) and I had this error, when you run getuid it says it need to be run as administrator and always returns 6400000000.
What i found was, first you need to make sure secure boot is off, and on my ASUS board, I had to enable CSM (Compatibility Support Module) in the BIOS... Which proved to be a pain as it requires a dedicated graphics card to turn it on.. So once I fitted a graphics card, turned on CSM, getuid worked and returned the correct code..
So Autodata 3.45 works on an 11th Gen Intel® Core™ i5-11400 @ 2.60GHz with Windows 11 Home (x64) - I think it will mainly depend on what options you have available in the BIOS.
Do you have a source where I can download this again? If not, would you be able to seed it somewhere?
I have a problem generating license.reg, it always generates empty file. Can somebody please generate license with UID: ea9a5884 and upload or PM me plz.
EDIT: nevermind, i managed to generate the license.reg on an old laptop. Autodata works now
Update: I found out that the nodongle emulator stops USB pen drives from working, the first one you plug in after a reboot works, but if you unplug and try another, Windows shows an error in device manager saying something along the lines of Error 38 could not load driver as it's already in memory, stopping the emulator and rebooting makes the USB drives work again.. So I went with a virtual XP machine to run Autodata
Hello I've tried the steps in your instruction file but I kept getting the same error when I run Autodata 3.45
dongle looked properly installed, UAC is disabled and the window antivirus is disabled too
running on windows 10 22H2 on a Oracle VM
When you run the keygen do you get the 6400000000 code ? if so it probably won't work till you get it to show another number.
