autodata rruntime 217 at 00580d29
Dos1392
hi all, first time posting, ive been looking through the other posts and am yet to find this errorr.
i have een getting it on a clean install of windows 7:
autodata runtime 217 at 00580d29
have tried reinstalling and still no luck, have followed every singe step by step, ut tto no avil.
any help would be great.
thans.
dan
crackwhore
Aug 24, 2017
8
I have win 10 x64 and I first got a sentinel error, so I did
Run command prompt as administrator, type "cd c:\adcda2" without quotes and then type "regsvr32 ChilkatCrypt2.dll"
and then it changed to a runtime 217 error and then I got a new error about not matching the hardware, so I reran the getuid and keygen step but no difference
8,887
It wont work on windows 10, try one windows 7 or windows XP.
crackwhore
Aug 24, 2017
8
I tried
Windows 7 - didnt work
Windows XP - works fine
Windows XP virtual machine within Windows 7 - gets error about "Sentinel key not found" when I launch the program
Has anyone had any success with this program running in a VM?
crackwhore
Aug 24, 2017
8
The problem with the Virtual Machine (VMWare) is that when I run GetUid it gives a different value every time I restart the VM OS, I have tried the HW ID from the host OS as well but that doesnt work either so I guess this software will only run on a PC running XP
I am now trying it in Virtual Box and will update
With virtual box it gives the same HW ID each time and it works!!!
75
78
