ARCADIAN
- Jan 11, 2018
Hello I Have a Hard drive in which I cloned with Reflect Maricum, its copied the drive right before it crashed a week later. I can make a copy of the drive, but it doesnt read a certain point of the drive, its Boots up in a laptop fine, But when i put it in a certain CNC machine which I got the original from, its wont read it, just gives me a blank screen with a flashing cursor. If i put this copied drive to a old laptop its boot up. Okay the CNC machine uses a Epson D486 PC card, has an OLD bios, I can access the bios no problem make changes, but it wont read the HDD.
Anyways The point i am asking which cloning programs do you guys prefer, This cnc machine uses a win95 booting but i cant tell how they made it I think it Windows 95C very small version of it. I used reflect MAricum, Just curious on what you guys might used, Clonezilla, Easus, Minitool, HDD Raw Copy. Is there a real sector to sector copier?? I think i can fix this drive by replacing the PCB I am waiting for it to arrive, but til then, which Cloning software do you Guys Like.
Thanks !!
Appreciate any Direction or Suggestions.
Thanks !!
