website stat Help with Adobe Acrobat Pro DC 2026 v26.001.21346 (x64) | The Windows Forum
dylanspackman
Hello Windows Forum. I'm a long time viewer, now first time poster. I installed Adobe Acrobat Pro DC 2026 v26.001.21346 (x64) from AppDoze.net. I followed all of the instructions and maybe did a few extra steps after the problems I was having with the 2023 version from thumper. Did all the patching and firewall blocking but maybe a little too much. Now when I try to open the application it gets stuck at this part. Please see attached screen clip for details. If anyone is willing to help me out or maybe give me instructions for a complete uninstall and how to install again properly it would be greatly appreciated. Thank you in advance for your help with this and also thank you for all the help I have received from this forum without ever even posting. :)
I did get uninstalr last night and it found a ton of leftover avg files so yes thank you for that suggestion. I guess I basically need to start over
it is the best solution... do you really need Acrobat? there are other PDF creation software around...
you could find some at 1337.to...
Is there other software that let's you edit already created pdfs the same way acrobat does?
I did get uninstalr last night and it found a ton of leftover avg files so yes thank you for that suggestion. I guess I basically need to start over?
Right. I have a suggestion. Install Revo Uninstaller Pro. With Revo there is an option "Install Program with Revo Uninstaller Pro". It traces everything installed.
Then there is another function Traced Programs. It saves a tremendous amount of time if you use that option to uninstall a Traced Program. After that I select a "Deep Scan" and it shows leftovers like folders and in the Registry.
I have the same issue could someone provide a step by step guide on downloading adobe acrobat?
