Help with your Office Pro Plus 2016 v16.0.4266.1003 RTM
Re: Help with your Office Pro Plus 2016 v16.0.4266.1003 RTM + Activator
<r><QUOTE author="ThumperTM"><s>
ThumperTM said:
</s><QUOTE author="aregowe"><s>
aregowe said:
</s>I'm running Windows 10 64-bit and I keep getting this error:<br/>
<br/>
"Error Code: 0-1018 (0)" and have no clue what to do. <br/>
<br/>
I renamed the directories, deleted the readme files, moved everything appears to look fine. For instance, my directory for the setup.exe is:<br/>
<br/>
C:\Users\user\Documents\fun1\msopp\setup.exe<br/>
<br/>
Not really sure what to do at this point. Any ideas?<e>
</e></QUOTE>
Disable your antiviris make sure to run it as adminitrator.<e>
</e></QUOTE>
The only av on my PC is that Windows Defender program, I already had that disabled, and every time I ran the setup.exe, I right clicked and hit Run as Administrator. And that's when I receive the error. <E>:(</E></r>
I was able to get this to work, then I ran malwarebytes, and lo and behold- this installed a ton of malware on my computer. Now I'm doing cleanup. Just figured I should warn everyone
I need your help.
I'm Brazilian, sorry by the wrong words.
This archive "rar" is with password. I don't know how to.
I need your help.
I need your help.
Hey cant log into my microsoft account via word / excel etc can on onedrive.
i was able to then i did a full windows reinstall, reinstalled this like last time but it wont log me in, not urgent just annoying really :D
ideas?
(log in screen comes up i add email and password but doesnt log in just goes back to word window still logged out)
Thank You In Advance
James
ideas?
James
Just attempting a re-install now ill edit with the result x
FIXED
Thanks for the Great Work on this software!!!
[highlight=red]when i can spare a bit of money ill pop donation[/highlight]
Already have a file with an existing "List" on another Word document (done as expected, with insert table and filling in all fields/records/registers) with it already loaded as the designated database for recipients; as I start the process by going into MAILING > Selecting LETTERS under START MAIL MERGE > then go ahead and finish up by clicking over the far right on FINISH & MERGE, choose EDIT INDIVIDUAL DOCUMENTS > SELECT ALL. What happens afterwards is that I do get a new Document with all the different copies of the letters I wanted, but I CANNOT save them anywhere on my computer given that when I try to do so, Word just crashes and reboots ending up right where I started, leaving me empty handed of the merged copies.
Has anyone experienced the same problem?
Any tips/help you can provide?
Is it just me, failure in the installation/validation process?
Let me know, I need this for work.
I need your help.
