Help with your Office Pro Plus 2016 v16.0.4266.1003 RTM
Scottmen
Seem to be having this issue once extracted: http://i.imgur.com/plVkJQ6.png
how to solve please?
EDIT:
and also I accidentally remember clicking "Activate Windows" when I got my Windows 10 back then, now it just says Activate Windows in the bottom right corner.. fix also for that?
lakersloyalty
Re: Help with your Office Pro Plus 2016 v16.0.4266.1003 RTM + Activator
<t>Hello.<br/>
<br/>
I get a Error Code: 30180-4 when I try to run your Setup. <br/>
<br/>
The message reads:<br/>
<br/>
Something Went Wrong<br/>
We're sorry, we couldn't install Office . Please make sure you're connected to the Internet, then retry your installation.<br/>
<br/>
You can go online for more help.<br/>
Error Code: 30180-4<br/>
<br/>
----<br/>
<br/>
You see I am very much connected to the internet, so this error doesn't make sense.<br/>
<br/>
Kindly help me.</t>
8,942
<r><QUOTE author="Scottmen"><s>
Scottmen said:
</s>Seem to be having this issue once extracted: <URL url="http://i.imgur.com/plVkJQ6.png">http://i.imgur.com/plVkJQ6.png</URL><br/>
how to solve please?<br/>
EDIT:<br/>
and also I accidentally remember clicking "Activate Windows" when I got my Windows 10 back then, now it just says Activate Windows in the bottom right corner.. fix also for that?<e>
</e></QUOTE>
Disable your antivirus then run .exe file as administrator. It should do the tick <E>;)</E></r>
8,942
EDIT:<br/>
</e></QUOTE>
Rename folder to something shorter (like office or office 2016) then run setup again.<br/>
<br/>
Good luck.</r>
kisaky
<t>your torrent nolonger works on payretbay</t>
hrockh
<r>torrent works fine on pirate bay <E>:)</E></r>
yucelkrhsn
<t>çok teşekkür ederim..</t>
Ifti
<t>I tried using the KMS file and i tried to download a office key but it says key installing failed ran as administrator btw and i installed office first</t>
Ifti
<r>nvm thank you so much bro <E>:p</E> I didnt know u had to open word or something once then close then direct activate from there haha <E>:D</E> will post if i run into any issues in the future</r>
caturritox
<r>got prob finding the activaction patch or file<br/>
It says in the readme file "run patch file" <br/>
But i ran the setup and installed everything, but cannot find the activation or patch file...<br/>
Pls help <E>:)</E></r>
8,942
<r><QUOTE author="caturritox"><s>
caturritox said:
</s>got prob finding the activaction patch or file<br/>
Pls help <E>:)</E><e>
</e></QUOTE>
Probably your antivirus is blocking it.</r>
cwmw.andy
<r><QUOTE author="kisaky"><s>
kisaky said:
</s>your torrent nolonger works on payretbay<e>
</e></QUOTE>
Yah, The link shows up in search results, but leads to a middle earth torrent.... by a completely different user... at lest that's what happens for me right now.<br/>
<br/>
<br/>
MICROSOFT Office PRO Plus 2016 v16.0.4266.1003 RTM <br/>
<br/>
try following that link and let me know if it takes you to office 2016 torrent...</r>
spiralblitz
<t>so I accidently hit the activate windows button. now my windows is asking me to activate it. how do i undo this.</t>
Shutt3r5
<t>I have the same issue no activator in the download? Any help please?</t>
8,942
<t>I think your antivirus software is deleting it.</t>
spiralblitz
<r><QUOTE author="spiralblitz"><s>
spiralblitz said:
</s>so I accidently hit the activate windows button. now my windows is asking me to activate it. how do i undo this.<e>
</e></QUOTE>
Anyone?</r>
Feedback
<t>Where's the patch file?</t>
Feedback
<t>I can't find the patch file, how is it supose to look like? i read before it could be the antivirus...what to do?</t>
8,942
<t>Please read above comments.</t>
stevenwang9999
<t>Sorry, but where could we get a Chinese language pack? <br/>
<br/>
Seems that MS website now rejected to change the language surface to Chinese unless it is link-installed?<br/>
<br/>
Thank you for your help.</t>
Thread starter Title Forum Replies Date
R Microsoft Office Pro 2016 [HELP] Windows 8 and 7 Help and Support 3
G Help with microsoft office 2016 pro plus v16 + activator Windows 8 and 7 Help and Support 5
C Help with activating Office 2016 Windows 10 Help and Support 2
L Help with Microsoft office 2016 Activation Windows 10 Help and Support 3
A Office MAC 16.19 activation [help] Windows 8 and 7 Help and Support 2
S I need help with your Office 2016 + activator instructions Windows 8 and 7 Help and Support 50
J Please help with MS Office 2010 Activation Code using Vista Windows 8 and 7 Software Chat and Support 0
B help request to put a Windows 7 in FR Windows 8 and 7 Help and Support 1
F need help picking windows 10 Windows 10 Upgrade and Installation 2
B Windows 10 Need help installing Windows 10 onto laptop running off usb drive Windows 10 Help and Support 3
D Help me plss to fix Windows 8 and 7 Software Chat and Support 2
C Win10 Build 19042.631 - Network error help need Windows 10 Help and Support 9
DVDR_Dog Quickbooks Help! Windows 10 Software Chat and Support 4
K Hi all and mini help to acrobat pro 11 Windows 10 Software Chat and Support 2
N i got hacked, plz help Virus, Trojan, Spyware, and Malware Removal Help 8
D Help! Im stuck don't know what to do anymore, 3 times BSOD makes my SSD RAW :( Windows 10 Help and Support 4
E Windows 10 Seeking Help in Free upgradation of Windows 10 Home Single Language to Professional Windows 10 Upgrade and Installation 7
W EFI partition size - please help after clean install Win 10 for Multiboot Windows 10 Upgrade and Installation 5
thief89 AnyDVD HD 8.4.4.0 HELP! Windows 8 and 7 Software Chat and Support 2
A help needed Windows 10 Help and Support 5
DVDR_Dog Need Help With an Odd Format Smartphones and other Devices Chat & Support 7
N Windows 10 Wondershare Filmora 8.7.4.0 help Windows 10 Help and Support 7
NickLAranda [Help] Dell Inspiron E5440 - Fan Pulsing Issues Windows 10 Hardware Chat and Support 4
O HELP windows 8.1 problems Windows 8 and 7 Help and Support 1
J I need help installing the premium version of Malwarebytes. Windows 8 and 7 Help and Support 1
G autodata 3.45 test mode disable help Windows 10 Help and Support 2
A Adobe Acrobat XI Pro install and crack...HELP Windows 8 and 7 Software Chat and Support 0
B Need help installing FolderLock 7.5.2. Windows 8 and 7 Software Chat and Support 0
T Need Help for Internet Download Manager 6.28 Build 7 Portable Windows 8 and 7 Help and Support 0
R HELP! Network Infected Virus, Trojan, Spyware, and Malware Removal Help 5
N Help with Avast! Premier - Scans not working Windows 8 and 7 Help and Support 2
B Microsoft Windows 10 1607 Oct HELP !! Windows 8 and 7 Help and Support 0
C HELP HOW TO USE KMSpico 10.1.8 FINAL Windows 8 and 7 Help and Support 3
M HELP: compress video to email! Windows 8 and 7 Help and Support 1
B im just ignorant and need help... Windows 8 and 7 Help and Support 1
R Natural Reader Help with voices Windows 8 and 7 Help and Support 0
M avg torrent help Windows 8 and 7 Software Chat and Support 1
S CCleaner help Windows 8 and 7 Help and Support 2
Z SlySoft 7.6.8.0 *help* Windows 8 and 7 Help and Support 0
E Please help! Windows 8 and 7 Help and Support 1
C new guy & need help Windows 8 and 7 Software Chat and Support 6
Z [HELP] Windows 10 Not Activated Permanent Windows 8 and 7 Help and Support 1
V Windows Toolkit/KMSpico help! Windows 8 and 7 Help and Support 1
S help me choose the right windows for me Windows 8 and 7 Software Chat and Support 3
T Windows XP setup HELP Windows 8 and 7 Help and Support 1
A Photoshop CC 2015 Portable help Windows 8 and 7 Help and Support 7
N Need help with uTorrent 3.4.2 Windows 8 and 7 Help and Support 5
F Camtasia 8.4.4 help! Windows 8 and 7 Software Chat and Support 1
D Help with KMS Windows 8 and 7 Software Chat and Support 0
S I am completely LOST!! PLEASE HELP!!! Windows 8 and 7 Help and Support 1
81
85
