Illustrator 2023 not working.
ArcaneHunter
I had been running illustrator and photoshop 2015 but I bough a new pc and had to install photoshop/illustrator again. I download the ones from piratebay and "Adobe Photoshop 2023 24.2.0.315 (x64) + Crack [TheWindowsForum]" is working properly following the tutorial. But when I try to install Illustrator it gives me error 182 and the installation does not proceed. I tried to downloading again 2 times, restarting. I tried removed photoshop and installing it first but get the same error(reinstalling photoshop gave me no error). Is there a fix? Is this a known issue? The Illustrator version I got was "Adobe Illustrator 2023 27.2.0.339 (x64) [TheWindowsForum]" both the photoshop and illustrator redirect me to this forum but while there is a post about photoshop there is none about illustrator.
Edit: If that version doesn't work anymore just say and I will try one from 1337x never downloaded anything from there only from PTB but while reading this forum people are commenting there is safer than the PTB now and PTB should not be considered safe anymore.
Maybe try some newer versions...
I normally use 1337x and log in. Then I select "Sort by Time". You have to log in if you want to write comments. Recently I have installed Adobe Acrobat Pro DC 2025 and Camtasia 2025.
Dumb question to ask, BUT !!!!
Adobe is notorious for a "Call mama during installation call" after all some naughty boy might be wanting to play her precious programs.
Where Adobe is concerned always check you have had a talk to the windows "hosts" file prior to doing anything to one of their programs, regardless of whatever.
Old addage from back in the day.
So... Ive been using Adobe Illustrator 2023 27.2.0.339 (x64) for a while with no issues, today it called home, despite having blocked over 100 of adobes addresses in the host file, and gave me 5 days to purchase a license, in thai language..
Anyone have an idea of what happened?
Thanks!
