Sleep mode doesn’t work in my PC
Ellina Ruz
iOS
Chrome Mobile 92.0.4515.90
I am using a PC with windows 10 and from few days before started having problems with sleep mode. It doesn't work on my computer. I tried some of the solutions given in some websites but still, have the problem.Any suggestions to correct this?
Thanks in advance
Kayla Brown
iOS
Thanks in advance
First of all check whether the sleep mode is enabled in your computer. You can do this by going to system and select power and sleep option. Then edit the values accordingly which are under the Sleep section and exit.Restoring the Advanced Power Settingsfor the active Power Plan would also help.
Do Scan for viruses.perform a deep system scan using a third-party antivirus or Windows Defender.
Remove peripheral devices.Usually, a mouse or a keyboard won't cause these kinds of problems. But webcams, printers, or SD readers will.
Disable Hybrid Mode.if you have enabled Hybrid Mode in an older PC there is a high chance that your PC won't go to sleep. Go to the additional power settings in system and select the preferred Power Plan you are using and click Change plan settings. Then click change advanced power settings, then from the three menu expand Sleep, then expand Allow Hybrid sleep and turn it OFF
Also try by Changing Advanced Power Settings
62
64
