Trying to build a custom ISO without internet components
dunnetahl
On Saturday I used this guide:
to create a custom ISO without a bunch of the bloatware in windows 11 that I didn't want. It mostly worked but I removed a few too many components and broke some functionality I needed so I was trying to take another crack at it Monday and the uupdump.net site has been down. I have tried downloading several other ISOs and even used the suggestion here:
to access uupdump.net through a local host and download an ISO that way, which seemed identical to how I did it on Saturday but every other ISO since the one I got on Saturday, then I get to step 11 in the Using MSMG Toolkit to Slim Down Windows 11 section, all the windows components have an * and cannot be marked for removal.
I can't seem to figure out what I might be doing wrong here, I'm going to try some of the uupdump mirrors people have suggested but the only other thing I can think that is different is that I am using Windows 11 now instead of Windows 10. Not sure if that would affect the MSMG Toolkit in some way.
Any suggestions anyone might have would be helpful. Thanks.
I am not familiar with that software. Anything you can share with your fellow members would be appreciated, at least I am sure I would. Thanks.
Thanks for the reply. I don't know anything about the software other than following the guide to a T and it working when uupdump.net was up but now I've tried downloading ISOs through the localhost and through https://www.uupdump.cn/ and through https://www.uup.ee/ and all of those ISOs * on the internet components trying to remove them with the MSMG tool.
I have even tried re-installing Windows 10 just like I was using when it worked.
At this point I'm not really sure what to try. I have no explanation for why the toolkit allowed me to remove the internet components with the ISO downloaded directly from uupdump.net but not through any of these other avenues.
I would appreciate any suggestions anyone has. Thanks.
