website stat Mercedes EWA / EPC / WIS | Page 2 | The Windows Forum
Status
Not open for further replies.
hi i have downloadet
epc_0916_1of3 a1
epc_0916_2of3_a2
epc_0916_3of3_a3
epc_1016_1of1b1
every time i try to install epc database in ewa admin tool i get an error of java(tm) platform SE binary has stopped working ? i found out it is only if i mount epc_1016_1of1b1 but if i only mount epc_0916_1of3_a1 it says no valid EPC medium found on the system ? what can i do? or am i doing something wrong? it is on a windows 7 pc i have tried on a windows 10 pc but it says the ewa network is running but its my first download i have tried the removel tool :)
Please help me with the WIS key, my MAC is 00216A11508D .
EPC working fine, I dont get it, before update the key was valid.
thanks in advance.
Hi Thumper,
I just finished installed EWA Mercedes from Mercedes EWA net By http://www.Techtools.ME.
EPC database already installed and running, but when i running EWA there's no EPC Program button that i can see.
Also i couldn't install WIS, it's said i've invalid key.
I Need your suggestion how to show or find the epc button on program & how to installed WIS.
Thanks in advance for your kindly help me.
Hello , can anyone help me with the startkey for wis mac : 04209A4191E3. Thank you
My MAC is 00306767DF16.
Installed EWA, stuck on WIS. The key is invalid.
Can you help me generate correct key?
Thanks!
My MAC is 985FD34B6FC2
Thank you!
Same problem here with the invalid WIS key. I tried to sent a PM to ThumperTM but the message stays in the outbox ,not sure it is sent.
having same problem wis valid check box not marked...also having trouble with epc database exracting files from mounted iso...please help
Hi, can you help me with key for WIS and EPC. My MAC id is: 002522DFB1EF
09.2017
Hi guys!
I downloaded "Mercedes EWA-net v2.25.0.7 + EPC + WIS last updates" and i did everything as said in readme but when i want to install EPC and WIS it says that startkey is not correct. Can someone help me please?
One more question:
2. Open EWA admin tool > StartKey > then copy your MAC address
2.1 Extract archive file "NewEPCnet KEYGEN_TESTED_WORKING-By Techtools.me"
2.2 1) Press 'Analyze Key' and paste this key: ec9kv9zfvrglv3l9t79zqx24bqz5pa2 and OK!
2) After than, copy\paste your Lan ID...
3) NOW press 'Get Key'
Where do i have to paste MAC address and LAN ID?
Hey when i try install ewa, it says "the system files could not be installed".... so whats wrong?
Hello,
So I am having trouble installing the database. Every thing goes perfect until it reaches step 7.
I get this error:Warning.png
Thanks,
Give a try with "Yes".
Yes i did try that it just finishes the steps and nothing happens,
Maybe this could help I checked my log files and it says this: Transbase is not available
2020-10-06 22:53:04,930 WARN [TransbaseHandler] Could not install Test EPC net Database. The EPC net Transbase is not available!
2020-10-06 22:53:04,945 WARN [AdminToolGUIManager] EPC net installation Step 7: Test new EPC database failed!
2020-10-06 22:53:04,945 WARN [AdminToolGUIManager] EPC net installation Step 8: Install new EPC database failed!
Status
